Lower chain roller shredded
This is a discussion on Lower chain roller shredded within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I just got my 2002 Warrior back from the dealership. They installed a new RK chain, chain slider, front and rear sprockets. I took a ...
Old 03-17-2010, 09:44 PM   #1
View bluewarrior's Photo Gallery(0)
Default Lower chain roller shredded
I just got my 2002 Warrior back from the dealership. They installed a new RK chain, chain slider, front and rear sprockets. I took a ride when I got home and realized that lower chain roller was shredded. I went back to dealership and spent 20 bucks on a stock lower chain roller. I installed it and went for another ride around the block and could hear the chain rubbing on the metal guide where the roller was supposed to be, needless to say the roller was shredded again by the chain. Could it be that the chain is to tight or that I just need to purchase an aftermarket chain roller, such as the one TM designworks make. It looks like they have one with ball bearings and a heavier duty delrin plastic. Has anyone experienced this problem before?
bluewarrior is offline   Reply With Quote
Old 03-18-2010, 08:05 AM   #2
I ran mine without one for the 4 or 5 years I rode my warrior.
Old 03-18-2010, 09:13 AM   #3
Was the metal guide in place still?? or did you cut it off. My new chain is rubbing on that metal right now and it makes a noise. I would think that would probably cause unnecessary wear on my chain if I did not have one in place. Could it be rubbing cause chain is tight since it is new?
Old 03-18-2010, 10:39 AM   #4
View maniakmax350x's Photo Gallery(0)
Was the new roller you put on a rubbery soft material? or a very dense plastic type of material?
maniakmax350x is offline   Reply With Quote
Old 03-18-2010, 12:27 PM   #5
It was yamaha OEM part and it was soft roller with a plastic ring that fit inside the roller. Horrible design.
Old 03-18-2010, 01:51 PM   #6
cuz mine was shredded when i bought the atv. i replaced it with something i found on ebay. it was hard plastic not soft. i actually thought i may have bought the wrong one. but then noticed the top roller was softer. so maybe the bottom roller is meant to be a firm hard plastic.
still new to these things but throwing my 2cents.
this is the exact one i got....
MOOSE CHAIN ROLLER KAW KX SUZ RM YAM YZ WARRIOR BLASTER : eBay Motors (item 270536141316 end time Mar-24-10 19:49:37 PDT)
Old 03-18-2010, 06:57 PM   #7
Thanks for the input. I just purchased a roller similiar to that one, hopefully I won't shred that.
Old 03-19-2010, 08:21 AM   #8
I think the pin is threaded into the frame, I either took it out or it fell out.
Old 03-19-2010, 03:35 PM   #9
ag2560's Avatar
View ag2560's Photo Gallery(3)
Did anyone notice the chain is under the roller instead of on top of it. If you don`t run the chain the right way it will destroy that roller ever time.
ag2560 is offline   Reply With Quote
Old 03-20-2010, 06:43 AM   #10
i noticed but it didnt quite register... hmm then it should be riding on some metal and chewing up the chain???
Old 03-20-2010, 10:10 PM   #11
OK that makes sense. I had the dealership put the new chain and sprockets on and that is how they assembled. If you are correct and the chain should be above the roller then the dealer screwed up when they put it back together. I should have done this myself! You would think the dealer would know what they were doing.
Old 03-20-2010, 10:48 PM   #12
If someone could post a pic of what the chain should look like when it is mounted properly above the roller it would be appreciated. Not to say that I don't believe the previous post but just have nothing to reference.
Old 03-23-2010, 01:16 PM   #13
Running 100's Avatar
View Running 100's Photo Gallery(3)
I just recently cut the mount for my roller off because my roller broke up and fell off, making the chain rub the mount. Guess I saved a few dollars...
Running 100 is offline   Reply With Quote
Old 04-22-2010, 02:05 PM   #14
shontobear's Avatar
View shontobear's Photo Gallery(0)
Default Warrior Chain Roller
Can someone post a picture of their chain rollers? I bought a 94 Warrior that does not have any chain rollers on it. And I am going to buy a new chain and sprockets.
God bless!
shontobear is offline   Reply With Quote
Old 04-22-2010, 05:23 PM   #15
View mikezx9r's Photo Gallery(0)
What is the purpose of the chain roller? What if you remove it like someone previosuly posted?
mikezx9r is offline   Reply With Quote
Old 04-23-2010, 03:18 AM   #16
View warrior392's Photo Gallery(0)
I made a set of rollers by turning down a couple of old skateboard wheels in a lathe. They have been on for 2 yrs and have held up well.
warrior392 is offline   Reply With Quote
Old 04-23-2010, 07:48 PM   #17
View warrior56's Photo Gallery(0)
The lower chain roller doesn't really do that much. I know that the stock foam ones are junk. You can put any aftermarket one on even from a dirt bike. I run an AMP Link on mine and love it.
warrior56 is offline   Reply With Quote
Visitors found this page by searching for these keywords:
yamaha banshee chain roller
yamaha raptor chain roller bearings
how to mount atv chain roller
yamaha warrior chain roller
350 warrior chain roller
please help chain roller? terrymo Yamaha YFZ450/450R (2004-Present) 4 03-11-2009 02:08 PM
Lower chain roller?? bigmackloud Yamaha YFM350 Raptor/Warrior ('87-Present) 18 04-21-2005 05:25 PM
Lower chain roller 250rAL Yamaha YFS200 Blaster ('88-Present) 7 08-23-2004 08:36 AM
lower chain roller? Big-Red23 Yamaha YFM350 Raptor/Warrior ('87-Present) 2 05-27-2004 08:05 PM
