Timing help
This is a discussion on Timing help within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; hey guys i fixed the clutch got evrything running ok but still back fireing. 2002 warrior, i have the covers off, i am getting the ...
Old 02-08-2010, 02:19 PM   #1
View epflynn's Photo Gallery(0)
Default Timing help
hey guys i fixed the clutch got evrything running ok but still back fireing. 2002 warrior, i have the covers off, i am getting the flywheel spun until i see the T lined up, but when the T is lined up the mark on the timing gear is @ the bottom, i thought it was supposed to be @ the top aligned with the V mark on the case, if so how do i correct this, also it is idleling fine but when i throttle up it just boggs down like it wants to stall and back fires, any help would be greatly appreciated, trying to get out in the snow with my son, thanks
epflynn is offline   Reply With Quote
Old 02-08-2010, 02:50 PM   #2
hey guys i believe i am 180 degrees out, what is the process for correcting this, thanks again, i can send pics if anyone needs them or is interested, thanks
Old 02-08-2010, 09:39 PM   #3
nevermind, i fixed the problem, to anyone who has this problem it was the emergancy brake lever since the cable was loose for what ever reason it causes the backfireing and bad throttle response, maybe this would make a good sticky, also the timeing was set by spining the flywheel bolt counter clockwise until the cam gear mark was aligned with the top notch on engine case and @ TDC
Bookmarks
Timing Pattch Yamaha YFM660R Raptor (2001-2005) 12 02-03-2007 09:09 AM
cam timing help yanks5166 Yamaha YFZ450/450R (2004-Present) 1 06-01-2005 03:52 PM
timing jmoney Yamaha YFM660R Raptor (2001-2005) 1 04-29-2004 11:11 PM
Cam Timing? Blksnshn Yamaha YFM660R Raptor (2001-2005) 3 05-03-2003 02:50 AM
Cam Timing? Blksnshn Yamaha YFM660R Raptor (2001-2005) 2 04-09-2003 04:07 PM
