warrior carrier bearing help
This is a discussion on warrior carrier bearing help within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; trying to get drive shaft seperated from the carrier, it is off the bike the only thing that is attached is the disc brake rotor, ...
Old 11-20-2009, 04:10 PM   #1
View epflynn's Photo Gallery(0)
Default warrior carrier bearing help
trying to get drive shaft seperated from the carrier, it is off the bike the only thing that is attached is the disc brake rotor, does anyone know how this comes off the axle. it is pretty rusty so i am not sure whether there are threads or you just tap it off with a rubber mallet like i did with the sprocket side any help would be awsome, it is a 2002 warrior 350. the carrier is shot so not concerned if it gets hurt but i don't want to hurt my axle Thanks
epflynn is offline   Reply With Quote
Old 11-20-2009, 07:41 PM   #2
Scout's Avatar
View Scout's Photo Gallery(0)
Do you have both nuts off of the carrier?
Scout
Wanted Warrior parts pm me if you have any forsale!!
Scout is offline   Reply With Quote
Old 11-20-2009, 07:52 PM   #3
yes scout everything is off the axle except the carrier and the disc brake hub, i am not sure how the dics brake hub comes off whether it is threaded or it just gets tapped off. it is kind of rusty thanks
Old 11-20-2009, 08:34 PM   #4
Scout's Avatar
Tapped off..
Scout
Old 11-20-2009, 08:50 PM   #5
so does that mean it can be knocked off with a rubber mallet, sorry not sure what taped off means
Old 11-20-2009, 09:37 PM   #6
Scout's Avatar
Yes, use some pb blaster or other penetrant, The tap it off with a hammer.
Scout
Old 11-20-2009, 09:38 PM   #7
Scout's Avatar
Hey man just call me and I will walk you through it...615-352-6064
Scout
Old 11-20-2009, 09:47 PM   #8
thanks bro i did use some pb blaster for the inner nut that shit works miracles i am getting some 2night so i'll give u a shout 2morrow thanks for the help
Old 11-21-2009, 12:28 PM   #9
whoa whoa whoa... the brake disk hub only come off to the left of the axle... you have to take the axle out of the carrier to get the actual brake hub off
Old 11-21-2009, 06:17 PM   #10
Scout's Avatar
Thats why I asked him if all the nuts were off.
Scout
Old 11-21-2009, 07:39 PM   #11
right.... but is said the carrier is still on the axle... it should all pretty much fall apart from here epflynn... unless you have loose balls inside of your carrier jamming things up
Old 11-22-2009, 09:53 AM   #12
the right side of the carrier is mess up, it is not useable, apparently the right rightr bearings went up the axle wobbles on the right side i soaked it with pb blaster last night gonna try get it off today, my question was i know the carrier supposedly slides off or can be tapped off from the 2 nut side, but does the hub holding the brake rotor tap off or is it threaded, scout said it tap's off scout sorry couldn't mess with it yesterday, gonna mess with it today. thanks for all the help guys
Old 11-22-2009, 08:25 PM   #13
got it off finally thanks to Scout. put the hub nut on backwards and pretty much banged it down on a piece of wood, and the disc hub slid right off to anyone doing this everything comes off from the left the only thing threaded is the main hub nuts. if it's stuck use some PB blaster the stuff works miracles. thanks for all the help expecially Scout your the man Bro
Old 11-23-2009, 08:25 AM   #14
pretty sure thats what i said.... or at least meant to
Bookmarks
New Bearing carrier WoodzRider01 Yamaha YFZ450/450R (2004-Present) 0 05-24-2005 10:52 PM
bearing carrier velocity-raptor Yamaha YFS200 Blaster ('88-Present) 6 02-14-2005 11:00 PM
lonestar bearing carrier and bearing velocity-raptor Yamaha YFM660R Raptor (2001-2005) 5 09-17-2004 01:35 AM
bearing carrier 660limited Yamaha YFM660R Raptor (2001-2005) 1 02-29-2004 10:37 AM
Bearing Carrier boomersooner Yamaha YFM660R Raptor (2001-2005) 4 04-02-2003 03:26 PM
