woodruff key on flywheel
This is a discussion on woodruff key on flywheel within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; waht would cause the woodruff key to keep breaking on the flywheel i have broken another one...
Old 07-10-2009, 07:18 PM   #1
View jbstacy's Photo Gallery(0)
very pissed woodruff key on flywheel
jbstacy is offline   Reply With Quote
Old 07-10-2009, 07:44 PM   #2
motorhead's Avatar
View motorhead's Photo Gallery(6)
well, what happens is after a key breaks once or twice the flywheel spins on the cranks and gets the hole out of round. To fix this a new flywheel is needed. But apply valve lapping compound on the crank and lightly seat the new flwheel, removing any burrs and nicks on the crank. Install a new oem key, tap the flyheel on lightly and torque the nut to specs. Dont forget to loctit the threads.
Trailtech flywheel
Trinity stage IV Exhaust
motorhead is offline   Reply With Quote
Old 07-12-2009, 12:38 PM   #3
yeah and if your not torquing the nut tight enought that will cause it to break.... if you are torquing it to spec you might want to try going a little tighter.... be definitly do what motorhead said first
Old 01-04-2010, 01:33 AM   #4
any other way of fixing the flywheel and crank besides buying a new flywheel
Old 01-04-2010, 08:58 AM   #5
lap the flywheel with valve lapping compound and then use blue loctite.
The problem with trying to tighten/glue the flywheel is, if you have any weird issues that may stop the motor quickly you could wind up with a broken crank.
06' Wolverine
Old 05-31-2010, 11:30 AM   #6
well i used the valve lapping compound and it helped getting the flywheel on but another problem has arose when i torque the bolt down and hit the starter the starter wants stay engaged if i loosen the bolt up it will disengage this warrior is getting to my last nerve if it aint one thing its another
Old 05-31-2010, 10:31 PM   #7
View 04rangerboy's Photo Gallery(0)
Heres the real trick; fill the tank full of gas, pour five gallons of gas in a tub low enough to fit under your bike, back up 50-75 feet shoot with bottle rockets! Now go to the dealership and pick up a new yfz450x (or R). didnt have to purchace a flywheel or crank!
Sorry I couldnt help myself I had to do it Ive been having issues with atvs lately too. (not my yams though!)
08' yfz 450 Velocity intake,k&n filter, DMC Afterburner silencer, ceramic coated head pipe,9 paddle haulers.cascade gas cap,
01' shee k&ns, fattys, 8" swingarm, redline built motor, pro design Cool head, 22cc domes,drag port port Pink race cut plastics (wifes bike)
04rangerboy is offline   Reply With Quote
Old 06-01-2010, 12:29 AM   #8
hey no prob i have thought of alot of ways of catching it on fire but i do wanna fix it
Old 05-31-2012, 08:32 PM   #9
View thascrambler's Photo Gallery(0)
Default great info
I have a 350 warrior i bought as parts that had this prob, sheared 3 keys before coming here (that wont happen again), the answers on this subject in this thread are dead on and worked awesome for me. I asked my machinist guy if he thought i could make my own from 1/4" square key stock (to keep from payin local dealership crazy prices) and he said yes it will work, and it may be the desired approach for someone who has really boogered things up because they could custom fit it to the damaged keyway and slot. Somehow my stuff wasnt damaged enough to go this route. With vernier scale in hand i measured what was left of the keys and found they are metric (duh lol), no metrics on hand here locally for me, so I decided to try a 3/16ths being it is almost identical in size (3/16ths is less than .009 smaller than 5mm, not enough to cause any timing issues and the morse taper is supposed to handle the majority of the work). I found napa/lowes/any hardware store w/ real selection has these on the shelf, its working at a fraction of the cost and no order n wait time. The cheapest i could find the "right" one for it was $4.08+s&h, rip off, i got mine for .58 cents, so I bought 3 n only needed 1 once i lapped the rotor to the crank. Definantly should tap the rotor into final place w/ a socket or pipe, dont wail it, just needs to be firmly seated. Done deal and riding the warrior again. Total cost including lapping compound and 2 extra keys was $7.06. If there is a next time on this machine i will get a 1/4" key and belt sand it to 5mm. I will post here again if the 3/16ths key has problems or if i shouldve used threadlock to enhance the tapers grip.
thascrambler is offline   Reply With Quote
Old 05-31-2012, 09:11 PM   #10
I kno this post is old, this prob w/ it not disengaging when torqued sounds like you are missing the washer behind the flywheel that keeps it from making positive contact w/ the lower timing chain sprocket.
banshee flywheel key
banshee woodruff key size
yamaha blaster woodruff key
yamaha banshee woodruff key
broken woodruff key grizzly
yamaha raptor 660 woodruff key
yamaha woodruff key
yamaha blaster timing key size
what size is a yamaha blaster fly wheel key
raptor 660 flywheel key
Flywheel strap for installing flywheel DavidBeebe Yamaha YFM660R Raptor (2001-2005) 2 07-13-2007 02:04 PM
woodruff key sheared up lorie Yamaha YFM660R Raptor (2001-2005) 10 06-25-2007 05:26 PM
Flywheel? sheeblue01 Yamaha YFZ350 Banshee (1987-Present) 7 12-21-2006 02:02 AM
Flywheel dave76 Yamaha YFM350 Raptor/Warrior ('87-Present) 1 11-13-2006 07:30 AM
I hope Yamaha fix the WR450 woodruff key problem first. raptorthumper Yamaha YFZ450/450R (2004-Present) 4 06-10-2003 05:50 PM
