Yamaha 350 Warrior Oil - Yamaha ATV Forum
This is a discussion on Yamaha 350 Warrior Oil within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I'm just bout to rebuild my 96 warrior's top end. This inculudes all the gaskets but not replacing the piston. I am also putting in ...
Old 06-09-2009, 08:30 PM   #1
Midwest Trail Rider's Avatar
View Midwest Trail Rider's Photo Gallery(0)
hehe Yamaha 350 Warrior Oil
I'm just bout to rebuild my 96 warrior's top end. This inculudes all the gaskets but not replacing the piston. I am also putting in a aftermarket clutch kit and already need to replace my oil. I was wondering what is the best oil to put in that will have a long life and be best for the engine. Include the weight.
Midwest Trail Rider is offline   Reply With Quote
Old 06-10-2009, 12:07 AM   #2
View warrior392's Photo Gallery(0)
This topic usually starts a good argument, but to answer your question I like to use Shell Rotella T.
warrior392 is offline   Reply With Quote
Old 06-10-2009, 08:26 AM   #3
you think oil starts arguements here?!? you should visit a snowmobile forum!!! 2 stroke oil arguments can last all winter!! hahaha i used some "thumper" stuff, its semi synthetic... it is what my dealer said was "the good stuff".... youll probably wanna just use some god ol' fashioned dino oil for the ~2hr break in tho since its just coming right back out.... i used the $10 a gallon stuff from walmart... then put "good stuff" in
Old 06-10-2009, 12:08 PM   #4
MGS
View MGS's Photo Gallery(0)
Bomber315,
I use Amsoil in all my quads. I use 20w50 motorcycle oil, in my 92 Warrior. Started with it from the first oil change when the quad was new in 92. No problems of any kind. Did a big bore kit about 4 years ago. Everything on the top end looked great- even the cam.
MGS is offline   Reply With Quote
Old 06-10-2009, 01:11 PM   #5
is amsoil fully synthetic? whats the price per gallon of that stuff? i recently have realized that my friend who works for a different dealer than "my dealer" can pump me some right out of the drum they have... all i have to do is supply the jug and pay cost... which im not sure how much of a deal it will really be since i buy all of my parts at cost from the neighborhood dealer as it is...
im really trying not to get into this conversation tho because i have seen where they can go... IMO as long as it is oil it is good..... he!! i run walmart brand 2 stroke oil in my 84 Vmax 540 sled.... it is a little sooty but its only like $10-15 a gallon... i used about 3 gallons last winter with no plug fouling issues at all... that of course is a sled and it doesnt have a wet clutch...
Old 06-10-2009, 01:33 PM   #6
I agree.. 15W 40
The diesel oils contain many of the elements that make your engine last longer.
Any oil formulated for Motorcycles or atv's is good too.
Old 06-10-2009, 06:23 PM   #7
MGS
Bomber315 it is fully synthetic, and it has excelent shear proportys, and also formulated for Wet Clutch systems. Around here I pay 8.00 per quart. I only change it once or twice per season. All depends on how much I get to ride. A good season for me is some where between 80 and 90 hrs of actual ride time, and I'll change it twice. The first in the spring and the 2nd in the middle. Some people think I'm crazy but it has worked just fine for me for a long time.
I'm sorry guys, I apologize up front but I don't like to use Rotella in anything that revs past 4500 RPM because it tends to aireate (foam). Diesels by design run low RPM's, and they don't run as hot either. They do run higher frictional loads yes but the other two factors cancel this out. I checked out the Shell oil Forum, and they admit to never testing the organic or synthetic versions in motorcycles. I know allot of guys use it and swear buy it, but it's not really formulated for ATV's or motorcycles buy Shell's own admission.
As a gear head, I'm blessed to have a job in the Automotive prototype engine development Field. I get to see all kinds of weird one off designs, as well as lube test results. Rotella is absolutely great for Diesels, but I wouldn't recommend it in a high RPM high heat application.
Bomber, your right this is probably gonna piss off some of these guys. Again I apologize.
I'll say no more on this subjuct. So if you guys feel the need to blast me---I'll understand.
Old 06-10-2009, 07:06 PM   #8
MGS
Just went to the Shell web site. Looks like they just recently tested for the Jaso standard. Couldn't find any testing results though.
Ya I know I said I wasn't going to say anymore on this subject, but I have to. I don't want you guys to think I'm just spewing B.S.
Old 06-10-2009, 07:32 PM   #9
hahaha talking oil is like talking politics!! hahaha i take it all with a grain of salt tho...
im of course going to add fuel to the fire and ask you what you think of blue marble oils? i like to run it in my sled(when i have and extra $40 for a gallon) and im pretty sure they make 4 stroke oils too
Old 06-11-2009, 05:57 PM   #10
MGS
I've seen the Blue marble 2 stroke oil but I've never seen 4 stroke. I know they make something called rev it up or something like that but I think it's an additive. I've never used there products cause there not real prevalent around here, but what little I've heard has always been positive.
Old 06-11-2009, 08:07 PM   #11
well i might be wrong on the 4 stroke stuff.. i thought i saw it one thier website when i was looking for sponsorship info... i know one thing tho.. their 2 stoke oil rocks! very little smoke as advertised... but it is like $40 a gallon at cost
Old 06-11-2009, 08:43 PM   #12
View warrior350rider's Photo Gallery(0)
i just run yamalube straight from the yamaha dealer
warrior350rider is offline   Reply With Quote
Old 06-11-2009, 08:49 PM   #13
Yea i think i'm just gonna get yamalube or the 15w 40
2002 Warrior-Yea it's simple,kinda slow, and handles like a fully loaded semi compared to your bike but....it's mine and I'm proud.
Old 06-12-2009, 08:01 AM   #14
yeah just buy three quarts the warrior only takes 2.5 quarts. make sure to buy a new oil filter to
Old 04-29-2015, 06:07 PM   #15
View madmaxx's Photo Gallery(0)
Default will 2 cycle oil hurt the yamaha 350 warrior
my son put 2cycle oil in a 1999 yamaha warrior will it still work
madmaxx is offline   Reply With Quote
Old 04-29-2015, 06:27 PM   #16
what motor is on a 1999 yamaha warrior
Old 04-29-2015, 10:54 PM   #17
View cory52000's Photo Gallery(0)
it is a yfm 350. yes it will harm it DO NOT start it until you change oil and filter and i would do another oil change after about 2 hours. it will ruin your clutch and bearings.
cory52000 is offline   Reply With Quote
Old 05-20-2015, 09:37 PM   #18
Whatsyoursoc's Avatar
View Whatsyoursoc's Photo Gallery(0)
The beatings will continue UNTIL MORALE IMPROVES!!!! ;) Goldwing forum people seem to go with the Delo 400le and the Rotella T and get MANY, MANY miles out of their machines, BUT they are pretty LOW RPM engines...BUT can be CRANKED UP TOO. Red line on the "older" models (1100's) is 7500rpm's; the 1200's (84-87) is 6500rpm's, but people seem to send them higher than that. I don't know why a person would run a pretty big motor that fast as most of the torque is in by ~2500-2800 rpm and ALL of torque is in by ~5500 rpm and it is the torque that a person uses mostly. Smaller motors a person has to really get BUSY with it to get to the torque and HP... like...9000rpm (crotchrockets). No one has reported any problems with the clutch using "regular car oil"...just not to use the "energy conservation" oil with the round/yellow sticker on the back of the bottle (too slick, allegedly for the clutch).. but if we go with the "too slick" argument... so would Mobil 1 full synthetic oil be "too slick" y/n? M1 is too expensive for me anyways, so not a problem. the clutch is NOT hard to access on the Warrior, right? an hours job? and ~$50? I always figure... OIL is OIL is OIL, it wants CLEAN, FRESH, GOOD OIL... even if it is WM brand in my old POS 98 warrior. Read about a guy, was changing his motor oil at a guys house, saw ROYAL PURPLE OIL on the shelf, was in a hurry, grabbed it, put it in his motor and went out of town to an off road trip... made it to the edge of town and the motor seized up? OH YES, IT WAS ROYAL PURPLE OIL... TRANSMISSION OIL!!!! IF all else FAILS!!! READ THE DIRECTIONS!!!!! I KNOW, I KNOW, REAL MEN DONT READ DIRECTIONS!!!! take them to the B room and lock the DOOR ;) Goldwing owners manual reads, "any good quality motor oil of the proper viscosity will work." Oil has come so far in the last 20-30 years since my GL 1200 was made anyways. problem is... 84-87 GL 1200 require motor removal to replace clutch...$1500 to remove motor and replace $100 worth of parts, same with the stator/generator ($65 part & $1500 worth of work to take the motor out to get the stator out). That is all I have to say about that.
Whatsyoursoc is offline   Reply With Quote
Tags
rebuild, warrior
yamaha warrior 350 oil
what kind of oil goes in a yamaha warrior 350
yamaha warrior 350 what oil weight
what type of oil does a yamaha warrior use
yamaha warrior oil capacity
2001 yamaha warrior oil
2003 yamaha warrior 350 oil type
can you use rotella t4 in a yamaha warrior 350
1996 yamaha warrior oil viscosity
yamaha warrior oil type and capicity
engine oil for yamaha warrior
what kind of goes in a 06 350 warrior
2001 Yamaha Warrior kickassrider48 ATVs for Sale 2 12-20-2010 12:17 AM
yamaha warrior smoke warriorman2003 Yamaha YFM350 Raptor/Warrior ('87-Present) 2 03-08-2009 02:36 PM
yamaha warrior easy101 ATVs for Sale 0 05-13-2007 06:47 PM
Yamaha Warrior yamaha warrior Yamaha YFM350 Raptor/Warrior ('87-Present) 14 04-20-2004 09:49 AM
Yamaha warrior hoods XR50 Yamaha YFM350 Raptor/Warrior ('87-Present) 7 08-20-2003 04:32 PM
