carb setting help - Yamaha ATV Forum
carb setting help
This is a discussion on carb setting help within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; have an 01 warrior 350 need to tune the carb but i have never worked on one can some one please tell me how to ...
Old 05-01-2009, 02:02 AM   #1
View ericsloan's Photo Gallery(0)
Default carb setting help
have an 01 warrior 350 need to tune the carb but i have never worked on one can some one please tell me how to do this
ericsloan is offline   Reply With Quote
Old 05-01-2009, 02:00 PM   #2
idles high and rough hard to start please help never worked on carb before
Old 05-02-2009, 01:26 AM   #3
GREASY's Avatar
View GREASY's Photo Gallery(0)
Default CARB. ADJUSTMENT
ERIC; First of all you will need a repair manuel,in there are the base settings for your carb. preset it and then you can set the idle. Start there and write back if you still can't get it right. GOOD LUCK, GREASY
GREASY is offline   Reply With Quote
Old 05-02-2009, 03:15 PM   #4
my carb only has one screw except the air/fuel screw thats all to work with i have cleaned it two times now and still nothing
Old 05-02-2009, 04:55 PM   #5
i have had this quad for two months and finily got to ride for qurter mile then stopped towed back and cleaned card for the third time now will not evan start now just about to give up would really like to ride but dont know what to do
Old 05-05-2009, 07:26 PM   #6
View lowgmc796's Photo Gallery(0)
u need to take off and take apart clean put back together everything inside as far as screws all the wy in and air screw 2 turns out and more out richer no more then 3 turns this is just for idle mixture when u give gas rest of carb takes over take seat off and shut off gas and start from there some fresh gas in tank is always good if u drain into contanier throgh fuel line then add new
lowgmc796 is offline   Reply With Quote
yamaha warrior 350 carburetor adjustment
yamaha warrior 350 carb adjustment
yamaha warrior factory carb settings
warrior 350 carb settings
yamaha warrior 350 carb settings
03 yamaha warrior yfm 350 carb adjust
yamaha warrior carb settings
yamaha warrior 350 carb tuning
yfm350 carburetor setting
how to tune a 88 warrior 350 carburetor
how to set up carburetor on 2001 yamaha warrior atv
1998 350 warrior idle adjustment
shock setting alex tracy Yamaha YFM350 Raptor/Warrior ('87-Present) 1 05-25-2005 05:49 PM
stock carb setting help osu_josh Yamaha YFS200 Blaster ('88-Present) 3 02-27-2005 04:51 PM
Setting sag xlr8 Yamaha YFM660R Raptor (2001-2005) 9 03-30-2004 09:02 AM
setting sag on yfz superfastyfz450driver Yamaha YFZ450/450R (2004-Present) 3 01-14-2004 11:03 PM
