Snapped off the Exhaust bolts, How to remove? - Yamaha ATV Forum
post #1 of 17 Old 01-23-2009, 03:22 PM Thread Starter
Well taking the Warrior apart I went to remove the exhaust moanifold off the cylinder and the 1 remaining bolt snapped and the other one was already snapped off previously.
I know I need to drill a center hole and us a easy out but how do I get the remaining piece of the bolt lose enough to release with the easy out. I don't want to snap the easy out off in it. I've done that before.
jwrape is offline
post #2 of 17 Old 01-23-2009, 08:36 PM
warriorman2003's Avatar
ha, that exact same thing happened to me, i had to drill the hole completely bigger, and tap new threads in it, use a little bigger bolt, but you will have to waller out the flange where the bolt goes through on the exhaust so the bolt will fit through, or just buy a new head, cause that was a major headache for me. good luck!
warriorman2003 is offline
post #3 of 17 Old 01-24-2009, 06:11 AM Thread Starter
Oh, I was afraid of that.... Maybe if I soak it in some breaker fluid it might lossen up the rusty threads. I'm crossin' my fingers.
jwrape is offline
post #4 of 17 Old 01-24-2009, 11:02 AM
yea that prolly would work, is the head already off? its much easier if it is, that way the frame isnt in your way of your tools. use some PB penetrant, thats the best stuf ive used so far! good luck!
post #5 of 17 Old 01-24-2009, 11:14 AM Thread Starter
Yea, PB Penetrater is what i have to use.
Unfortunately the head is still on it. I figure I will turn the thing on it's butt so I can get a good view of it when I go to remove them. It will prolly be sometime early this week I get to it. I am cleaning the frame and painting first tonight while my wife is out with her girl friends.
jwrape is offline
post #6 of 17 Old 01-24-2009, 11:23 AM
Bowtie's Avatar
One of the biggest problems people run into with easy outs are they don't use the right size and they use one that is to small. When ever I have to use one, I always find the right size bolt to match what snapped and figure out how big I can go on the bit before I start cutting the threads and then I drill it out as close as I can and then insert the easy out. The key is getting your starter bit dead center and if need be, I have taken a die grinder with a metal cutting bit and flattened it so that I can get a good starting spot and the drill bit wont run on you. I also start very small on my first bit, and I let it cut with out to much pressure so that it doesn't snap. I have yet to break one using this method.
09 YFZR SE
05' YFZ 450 - Gone
00' Banshee - Gone
07'/06' YFZ 450 - Gone
Bowtie is offline
post #7 of 17 Old 01-24-2009, 11:26 AM Thread Starter
Ok, i will definately keep all that in mind. Thanks
jwrape is offline
post #8 of 17 Old 01-25-2009, 11:50 PM
dieseltech01s's Avatar
as a mechanic i have to do this all the time, dam ford exhaust manifolds. but the best thing i have found is take a wire welder and weld a nut on the end of it then let it cool. then turn them out works about 9 times out of 10. other than that, do like bowtie said but if you can use left hand drill bits. a lot of the time the drill bit will spin them out.
05 Raptor 719
4mm Barker Crank, 11:1 CP Piston, Mega Cycle X-3 Cam, RS3 Yoshi Full Exhaust
01 ish warrior 11:1 wiseco, stage, 1 hot cam, fmf pipe, k/n filter
dieseltech01s is offline
post #9 of 17 Old 01-28-2009, 12:15 PM Thread Starter
I would weld a nut on it if the head was off and I could set the net there while I welded it but there is no way to hold it there while I weld. I've got some PB blaster on it now. Iwill be drilling it out soon. But love that idea for other bolts later,
jwrape is offline
post #10 of 17 Old 01-28-2009, 06:47 PM
just take your time and if you drill make sure you get it centered
05 Raptor 719
post #11 of 17 Old 07-14-2010, 12:08 PM Thread Starter
I figured I would update this.
What I did was, after trying to drill it out while the Warrior was stood up on it's butt and failing, I remembered that my Suzuki LT500 Quadzilla had the exhaust Manifold held on by 3 springs. So I put on a Pipe Clamp and then proceeded to use 3 HD springs from Ace Hardware to spring load the exhaust Manifold to the head. Worked perfectly and is still holding great.
jwrape is offline
post #12 of 17 Old 07-17-2010, 12:17 AM
gixer311's Avatar
I just took my head off and gave it to some guy to get the broken ones out...just because the last ride I had, the exhaust came off the head (after trying to squeeze it to the head by other means).
gixer311 is offline
post #13 of 17 Old 07-23-2010, 12:02 AM
jimk's Avatar
Ok, i did the same thing, i didnt have a drill and tap set because i just got into a dispute and lost all my tools, so i look around the garage and what do i have? an angle grinder, so i removed the head, heated, and tapped the studs with a hammer, they still wouldnt budge, so i ground a notch on the side so my vice grips had something to grip, and it worked, got them out no prob. p.s. the upper stud under the wing was a pain in the ass. USE PATIENCE
All i need is a left handed metric crescent hammer
jimk is offline
post #14 of 17 Old 08-23-2010, 09:41 PM
Help
My bolts are both out but the threads are all stripped out, What are my options? i took the quad to a few welders but no one wanted to touch it. Should i retap the holes? I saw someone say they use springs, can you post photos on how you did this? any help would be great, I just picked up my Warrior for $450 and cant wait to get out and ride, but this problem is standing in the way! Thanks again!
childersdave is offline
post #15 of 17 Old 08-24-2010, 08:23 AM
you can retap them to 1/4 standard thread and go to the local hardware store and get some 1/4" studs. You may have to drill the exhaust flange.
post #16 of 17 Old 08-24-2010, 01:23 PM
The "springs" are helicoils, and they work great.
I just fixed mine and drilled it out and tapped it to a fine thread 1/4". I didn't have to drill the flange, but I may have been lucky.
BTW...don't forget the exhaust gasket...good chance that if the header was off, it was lost.
Bucket is offline
post #17 of 17 Old 08-27-2010, 08:30 PM
Ok so i was able to put a helicoil in the upper bolt hole, but the lower is a whole different story, there is no meat there and it just isnt working. I think im going to try to jb weld a threaded rod in there. Any thoughts?, i think im out of options.
went to do the clutch and the cover bolts snapped blackh8552 Yamaha YFM350 Raptor/Warrior ('87-Present) 7 09-18-2004 05:31 PM
How to remove Baffles from Stock Exhaust Fast03 Yamaha YFM660R Raptor (2001-2005) 8 05-27-2003 11:12 AM
Exhaust bolts snapping?? taco_warrior Yamaha YFM660R Raptor (2001-2005) 15 05-07-2003 04:44 PM
