Warrior transmission problems - Yamaha ATV Forum
This is a discussion on Warrior transmission problems within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I was riding wide open 6th gear and then the bike seemed to slip into neutral. Now i have no gears at all. i can ...
Old 07-19-2008, 08:22 AM   #1
View Adam Kinmond's Photo Gallery(0)
Default Warrior transmission problems
I was riding wide open 6th gear and then the bike seemed to slip into neutral. Now i have no gears at all. i can hear clicking when i shift. i was towed home, and figured the clutch was gone but it checked out OK, when i took the cover off. Anyone have any ideas??????
Adam Kinmond is offline   Reply With Quote
Old 07-21-2008, 12:27 PM   #2
runnallsraptor350's Avatar
View runnallsraptor350's Photo Gallery(0)
i now this sounds stupid but did your front sproket fall off it happened to me and i thought i took the transmissions out of mine (again) the first time i took it out i was in six it slipped into neutral then jumped down several gears when they took it apark every gear was chipped..?? i duno tear it apart and find out..
05 raptor 366 blue to many mods to list (sold- traded for AC sno pro 440)
07 Phazer fx.
Sorry Guys 06 predator New on the floor $5000 stock fox podiums
runnallsraptor350 is offline   Reply With Quote
Old 07-21-2008, 12:45 PM   #3
View florida redneck's Photo Gallery(0)
Mine does it but I took my reverse linkage out (I stripped the bolt that holds it to the case). So every now and they it will slip between what ever gear I'm in into a neutral like gear.
florida redneck is offline   Reply With Quote
Old 07-22-2008, 01:14 AM   #4
View WeekendWarrior's Photo Gallery(0)
Default tranny trouble
Check the Phillips head screw on the end of the the SHIFT CAM ASSY. it can come lose and do just what your describing. I had it happen to me on 2 different warriors.if this is the case besure to put some locktight on the screw to keep it from happing again.hope this helps and good luck.
Happy Trails
WeekendWarrior is offline   Reply With Quote
Old 08-16-2008, 04:19 PM   #5
thanks for your replies. it was the fwd/rev lever popped out.
Old 08-27-2008, 06:20 PM   #6
extinctshee06's Avatar
View extinctshee06's Photo Gallery(0)
ive had that happen to mine but under heavy load like when it drags my fat ass up a big hill. usualy second or third gear tho. i still dont know the problem since its only done it two or three times.
06 banshee SE toomey t5 pipes, K&N proflo
04 raptor 350 yosh pipe, K&N proflo, hotcams
86 moto 4 200- too fast for mods
2005 skidoo mxz adrenaline 800 ho- studs cpi glasspack
extinctshee06 is offline   Reply With Quote
Old 08-04-2013, 09:55 PM   #7
ropegunwarrior's Avatar
View ropegunwarrior's Photo Gallery(0)
im having the opposite problem , I can move in 2nd but all my other gears are locked up .
ropegunwarrior is offline   Reply With Quote
yamaha warrior transmission problems
yamaha warrior 350 transmission problems
yamaha warrior transmission recall
yamaha 350 warrior transmission
2001 yamaha warrior 350 transmission
how to check transmition fluid on a 1998 350 worrier
99 warior transmissoin how many gears
yamaha warrior 350 troubleshooting
no gears on raptor 350
transmission clicking warrior 350
Rappy Transmission Problems rocketpig Yamaha YFM660R Raptor (2001-2005) 3 07-20-2005 05:40 PM
warrior problems littlebartz Yamaha YFM350 Raptor/Warrior ('87-Present) 2 04-24-2004 10:07 AM
YFZ-450 TRANSMISSION PROBLEMS? NO WORRIES! daddogrider Yamaha YFZ450/450R (2004-Present) 17 04-01-2004 02:18 AM
How complicated is the Warrior Transmission? Sharptj Yamaha YFM350 Raptor/Warrior ('87-Present) 14 11-01-2003 06:42 PM
Do late year 2001 Raptors have transmission problems? raptorboy02 Yamaha YFM660R Raptor (2001-2005) 14 06-21-2002 03:02 PM
