No starting and no spark - Yamaha ATV Forum
post #1 of 8 Old 07-06-2008, 06:08 PM Thread Starter
So we got this 1997 Warrior - another thread we were doing a rebuild.
Before we started the rebuild, it turned over at the handle bar switch and ran with no problem.
Took it down to the frame - painted. All new bearings. Rebuilt the top-end .20 over. Put the motor back in finally.
Hooked up the wiring harness the exact way it was hooked up before. Headlights light, taillight lights. Neutral light indicator doesn't light. Reverse indicator will light if put into reverse.
Hit the start button. Nothing. Clutch switch/kill switch flicks a relay. Tested that relay (the system starting safety relay) ok. Went to test the neutral relay and it's all burnt up looking - when tested it generated a butt load of heat and never triggers. So that's on the replacement list. But we started before this project so that is what is strange - I think it's always been bad because we had no neutral light before.
So is this the reason for no start button activity?
I jumped the starter solenoid and the bike cranked and fired right up. I shut it off. Adjusted idle/choke again. Fired it back up - let it run for a minute. Shut it off and topped off the oil. After it cooled down - I wanted to fire it up again and it just cranked cranked cranked cranked cranked.
Now it's getting no spark.
I've gone through the entire wiring harness. We're grounding.
I tested everything I could. Neutral Switch (stays ungrounded regardless of gear selected), and neutral relay appear to be bad. The starter, solenoid, switch controls, clutch switch all appear to be functioning. The key and is charging the brown wire. The blue/white and red/white wires going into the solenoid are both charged positive when the kill switch is off - when switched to run they both go to ground.
On the stator. I'm not sure what wires are which on the stator - there are 3 paired wires. I tested the 3 wire white harness that goes to the regulator and all testable pairs are just shy of 1ohm resistance which the manual says OK. I'm not sure about the other two paired wires coming out the stator - one measured 300 and the other measured 600. I'm assuming the 600 is an out of spec pick-up coil? Which might answer the no spark?
Also the CDI box looks like it's been heated up too much and has peddles melted into it. There is also a hole in it as well. And I can see the top of a capacitor melting through.
So right now. I'm nearly thinking we need a new stator, CDI, neutral switch and neutral relay.
Seriously... What the hell? :(
www.Ride-NY.com
2003 YZF-R1
2007 Raptor 700R
1997 Warrior 350
ZacUSNYR is offline
post #2 of 8 Old 07-07-2008, 08:18 AM
Sounds like you are on the right track.
I have never heard of a CDI being so beat up!
post #3 of 8 Old 07-07-2008, 09:00 AM Thread Starter
Yea tell me about it.
Sucks this is happening like this - my gf is so disappointed (this is her warrior). But hell once we get this all straightened out we're going to have a practically new warrior.
I went through the reverse lever yesterday - the thing was hard to pull up (nearly impossible for her to do it). I took the whole thing apart and it was packed with dirt. Had to soak it in PB Blaster and then clean it. Packed it in new grease and it's as smooth as butter now!
www.Ride-NY.com
2003 YZF-R1
2007 Raptor 700R
1997 Warrior 350
ZacUSNYR is offline
post #4 of 8 Old 07-07-2008, 05:27 PM
Sounds like someone put a battery charger on backwards on high and let it sit.. A bad short would cause these problems.
1998 Warrior. JE 366cc, Mega .450", HD TI valve springs, DR P&P head, DR flywheel, KW SS Oversized valves, TM36-68 Carb, Dyna DFS7P, HD Barnett clutch springs, Earl's custom oil cooler/big bear setup. AC Bumpers, Holeshot's with .190 rims.
Jasonp is offline
post #5 of 8 Old 07-08-2008, 07:18 AM Thread Starter
Wish it was that simple :( This was here before the battery even touched a charger.
www.Ride-NY.com
2003 YZF-R1
2007 Raptor 700R
1997 Warrior 350
ZacUSNYR is offline
post #6 of 8 Old 07-09-2008, 07:44 PM Thread Starter
Just ordered a gasket, neutral switch (with crush washer gasket), and neutral relay from MR Cycles and ordered a stator/cdi/ignition combo from rmstator.
I hope this project is finished soon! :)
www.Ride-NY.com
2003 YZF-R1
2007 Raptor 700R
1997 Warrior 350
ZacUSNYR is offline
post #7 of 8 Old 07-22-2008, 09:26 PM Thread Starter
CDI fixed sparking issue. Have a spare brand new stator now.
Starter still wouldn't kick, was such a simple problem that i am kicking myself for overlooking. The wire connection for the starter button (red/white wire on 96-01) was broke with a lot of corrosion - the tab was missing. Wasn't making a good connection. Fixed this and it started on it's own. Bought new relays for the neutral circuit and the system start circuit. Everything is working. Bike sounds and runs great!
I'll get the build thread updated with some new pics of it together shortly. Hoping to have it all done tomorrow night.
www.Ride-NY.com
2003 YZF-R1
2007 Raptor 700R
1997 Warrior 350
ZacUSNYR is offline
post #8 of 8 Old 07-23-2008, 08:20 AM
Awesome!
Tow starting bansheeboykek Yamaha YFZ350 Banshee (1987-Present) 6 09-16-2004 10:25 AM
Need some help with Starting wannaberider Yamaha YFM660R Raptor (2001-2005) 9 04-09-2004 04:13 PM
Not Starting? cbrf41999 Yamaha YFS200 Blaster ('88-Present) 2 11-04-2003 07:57 PM
Spark plug will not spark custom_warrior Yamaha YFM350 Raptor/Warrior ('87-Present) 3 09-22-2003 03:31 PM
Help! Not starting well Screamin00shee Yamaha YFZ350 Banshee (1987-Present) 12 06-06-2003 05:06 PM
