still smoking
This is a discussion on still smoking within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; so i put in a new piston and cam a while ago becuase my oil pump got cloged and burnt my cam and i desided ...
Old 01-23-2008, 07:55 PM   #1
View dirtrider596979's Photo Gallery(0)
Default still smoking
so i put in a new piston and cam a while ago becuase my oil pump got cloged and burnt my cam and i desided to put a piston in while i had it apart. when i put it back together it would smoke till it warmed up (usualy 30 seconds to a minute) then clear up, i figured it was my valve seals because the head was running dry, i just put in kibblewhite valvles, new seals and springs and put it together. when i started it it was fine. the next day i go to start it and it starts smoking again just like before then clear up in 30 seconds to a minute. what the hell else could it be, i installed the seals and everything myself, could i have done it wrong? i pulled the old ones off with pliers and tapped the new ones on with a socket that fit it good, using the valve as a guid to make sure it went on right. could my guids be f***ed up and making it smoke? it runs great but just smokes a little. also could it be the oil im running? im using cheep autozone brand 10w 40, it didnt smoke till i put that in, could it have an effect or no?
"89" warrior-**SOLD**-fmf megamax, White bros. mikuni 36 mm, weisco highcomp, hotcam stage one, kibble white valves, custom intake, 2001 plastics and headlights, razrs, oil cooler, msr handle bars, custom skid plate and bumper
"98" F150- Daily driver/quad hauler
kx 125-year un-known, still a box of parts
dirtrider596979 is offline   Reply With Quote
Old 01-25-2008, 06:33 PM   #2
runnallsraptor350's Avatar
View runnallsraptor350's Photo Gallery(0) Send a message via MSN to runnallsraptor350
my rappy smokes when its first started but only in cold weather its steam or fog or jsut the exhaust temerature becasue it goes away when the bike is warmed up and it doesnt do it warm weather
05 raptor 366 blue to many mods to list (sold- traded for AC sno pro 440)
07 Phazer fx.
Sorry Guys 06 predator New on the floor $5000 stock fox podiums
runnallsraptor350 is offline   Reply With Quote
Old 01-26-2008, 06:53 PM   #3
a4d
View a4d's Photo Gallery(0) Send a message via AIM to a4d
Maybe the oil scrapper on the piston is stuck. If it has one i don't know warrior pistons.
04 Raptor 686- Too much to list
06 Silverado Vortec Maxx- True dual flowmasters, and diablo tuned.
a4d is offline   Reply With Quote
Old 01-27-2008, 11:34 PM   #4
mine goes away once its warmed up but i kno its oil because you can smell it and it doesnt disapate rite away, i changed my oil the other day n it almost went away, then i went for a ride today and when i was engine breaking down a hill it did it and when i started it afterwards to drive it from the truck to the shed
Old 04-19-2008, 09:22 PM   #5
View cb1973's Photo Gallery(0)
another smoker
my son has a 1999 warrior that i bought about 2 months ago. it was smoking and i did a top end bored it 20 over and replaced the valve seals also. broke it in properly and three weeks later it started smoking at start up too. last about 30 seconds to 1 minuite.then it stops. i have done plenty of engine work before and i dont think it was improper installation.
cb1973 is offline   Reply With Quote
Old 04-19-2008, 11:31 PM   #6
Min has done that since I rebuilt it to, i just call it the Warrior prelube. It really can't hurt anything. I'm guessing it is most likely valve seal leak by. there is a good chance that the oil puddles the valve seal after shut down, which might let a little oil by as the quad sets.
Mine is never lwo on oil so I don't worry about it.
diggerzmound is online now   Reply With Quote
Old 04-29-2008, 10:10 PM   #7
View yamicurt's Photo Gallery(0)
Default similar problem on warrior
i just bought a 96 warrior and changed the oil, to know that it was fresh. the manual calls for 20w-40. the yamaha shop insisted on 20w-50. ever since i changed the oil, it smokes when first started and at no other time. could it be that the oil is too thick? any help would be great, since i am new to the sport. thanks, curt
yamicurt is offline   Reply With Quote
Old 05-31-2008, 08:45 AM   #8
View Odiekokee's Photo Gallery(0)
Default Smokes too....first quad
Well, I just bought my first 4-wheeler, almost on accident. Got what I think is a good price, machine runs good and in fairly good shape. '97 warrior.
Previous owner advised starting it with the fuel off, and then turning the fuel on. There is some fuel smoke in the exhaust. BUT there is also oil smoke. (I got it Thursday night, first ride yesterday about lunch, and gonna be a busy weekend so not alot of riding to do)
Just got the manual downloaded. Wondering if some good oil like Mobil, and using the one for high mileage with the seal conditioners and such would be worth the investment. I've never done heavy engine work, although i've had my first motorcycle bolt from bolt, with the exception that i never had the heads off or the cases split. That part was bulletproof and in great shape, so I left it be.....sorry, got off subject.
I'm open to suggestions on both the fuel and oil situations. Machine seems to be running with plenty of power and all, maybe I just call it upper cyl lube or somesuch and run the dog out of it.
Odiekokee is offline   Reply With Quote
Old 05-31-2008, 04:06 PM   #9
screaminshee'06's Avatar
View screaminshee'06's Photo Gallery(0) Send a message via AIM to screaminshee'06 Send a message via Yahoo to screaminshee'06
well first i would do a compression test and see what that looks like...second it could probally be bad valve seals...dump the oil and gas out and deff replace with new...see how that works first then repost if none works
2008 Raptor700-K&N,Two Brothers Full System,PCIII Coming Soon
2006 KTM 450XC-Added A Headlight,No Need For Anything Else
screaminshee'06 is offline   Reply With Quote
Bookmarks
660 Run low on oil, now smoking?? gm1brian Yamaha YFM660R Raptor (2001-2005) 14 10-26-2007 11:58 AM
New JE 10.75 and smoking and using oil. 03LimitedEditionRaptor Yamaha YFM660R Raptor (2001-2005) 3 06-01-2004 12:08 AM
Smoking Question RiPPiNiTuP7 Yamaha YFZ350 Banshee (1987-Present) 7 11-06-2001 11:02 PM
