2001 warrior only runs on full choke - Yamaha ATV Forum
post #1 of 5 Old 06-21-2007, 09:28 PM Thread Starter
quad ran perfect last time i rode about a month ago,
went to start is couple days ago and now it will only run with choke fully on,
So far ive cleaned the carb and changed the spark plug, still have same problem.
anybody have any ideas ?
Teck is offline
post #2 of 5 Old 06-22-2007, 12:48 AM
When you had your carb apart did you take out your jets and make sure there was no blockage? Also did you set your air screw back to where it should be?
Air filter nice and clean?
wilsonad is offline
post #3 of 5 Old 06-22-2007, 01:19 PM
Check the CARB JOINT. It is a metal tube wrapped in rubber between the engine and the carb (2"X3"). I went out riding and when I came back I had the same problem, would only run on high idle. Sometimes the split in the rubber is real fine, but it allows to much air into the system after everything has mixed in the carb. I have a 01' Warrior and after a few years this is a common problem. Good luck let me know if that was the problem.
07' yfz450
01' warrior
White Bros E2
Prodesign Filter
az350 is offline
post #4 of 5 Old 06-26-2007, 10:26 PM Thread Starter
BAD GAS!!!
thats all it was...
I always look for the worst and it ends up being the easiest thing
anyway - thanks for the help guys
Teck is offline
post #5 of 5 Old 06-26-2007, 10:58 PM
glad it is working!
wilsonad is offline
warrior 350 engine runs perfect spikedog Parts for Sale 3 04-11-2012 03:55 PM
Warrior Wont Run/Runs Like Crap Unlukky Yamaha YFM350 Raptor/Warrior ('87-Present) 12 10-19-2006 06:55 AM
Runs on choke only fcristiano Yamaha YFM660R Raptor (2001-2005) 7 12-24-2004 08:29 AM
Removing choke from 2001 Warrior Darryl Yamaha YFM350 Raptor/Warrior ('87-Present) 8 12-23-2004 06:34 AM
Warrior runs like crap. TreeFrog169 Yamaha YFM350 Raptor/Warrior ('87-Present) 5 09-30-2004 06:40 AM
