How hard is it to replace rear axle bearings in a 99 warrior - Yamaha ATV Forum
This is a discussion on How hard is it to replace rear axle bearings in a 99 warrior within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I just picked up a 99 warrior two days ago. I noticed when I was looking it over after I test drove it that the ...
Old 02-04-2007, 11:26 AM   #1
View 1bad85gt's Photo Gallery(0)
Default How hard is it to replace rear axle bearings in a 99 warrior
I just picked up a 99 warrior two days ago. I noticed when I was looking it over after I test drove it that the rear axle bearings were extremely sloppy. I have already ordered new front wheel bearings and rear axle bearings with seals and just was curious as to how hard it is to change the axle bearings. That and the chain is terribly loose as well. I'm assuming it is the factory chain and sprockets. The sprockets seem to be in decent shape but the chain is really loose. How do I tighten the chain as well?
1bad85gt is offline   Reply With Quote
Old 02-04-2007, 02:03 PM   #2
View Jasonp's Photo Gallery(0)
http://yfm350.proboards31.com/index....ead=1118340578
This should help.
1998 Warrior. JE 366cc, Mega .450", HD TI valve springs, DR P&P head, DR flywheel, KW SS Oversized valves, TM36-68 Carb, Dyna DFS7P, HD Barnett clutch springs, Earl's custom oil cooler/big bear setup. AC Bumpers, Holeshot's with .190 rims.
Jasonp is offline   Reply With Quote
Old 02-04-2007, 02:05 PM   #3
Warrior King's Avatar
View Warrior King's Photo Gallery(0)
Id did it come with the simple warrior manual? If it did the chain tightening instructions are in there, its not hard
The axel barrings can be done by your self for the most part, the only thing you need done is the new barrings pressed into the carrier. You can take the old ones out with a hammer and a block of wood.
Another note that could help you, when buying things like barrings, try to find machine places that just make generic parts and take in your old ones and have them match it up. Buying from Yamaha or any dealer they are going to charge an easy 40 bucks extra
Need a dirt bike :(
Warrior King is offline   Reply With Quote
Old 02-04-2007, 10:21 PM   #4
I ordered the complete front wheel bearings and rear axle bearings with seals for $30 from a bearing supplier that sells on ebay. The local yamaha dealership wanted $60 for just the rear axle bearings with seals.....lol.. I just picked up a new set of holeshot xct's for the front and rear and I'm going to get a new chain and sprocket set as well due to the chain being totally stretched, rusted, and worn out. I'm going to take the rear housing off tomorrow and hopefully get the old bearings out and then just take the housing to the shop and see if I can press the bearings in myself as well. I'm hoping all will go well.
Old 02-05-2007, 11:16 AM   #5
View Compufreek's Photo Gallery(0)
Yeah you can do it all yourself. Me and my cousin, rywarrior on here, did both our bikes. Even his where all the bearings had gone inside the carrier wasn't too bad just a little work. We also got them off ebay. Pressing them back in is not too bad they say to use a socket the size of the outside ring to tap it in but we used a big screw driver and tapped all around the outside edge.
Compufreek is offline   Reply With Quote
Old 02-05-2007, 04:04 PM   #6
View wie1086's Photo Gallery(0)
Putting it back together is easy. Getting the axle out of the carrier can be a pain if there is rust -- the inner race likes to hang on tight. Lots of grease when putting it back together.
Go for an xring chain. Before you buy check the price of chain sprocket set. Sometimes the difference is minimal between a chain and a set. Ebay it!
2007 700 Grizzly
2000 Warrior-traded in
2001 Warrior-traded in
http://ohiomafiariders.com/images/logos/omruserbar.gif
wie1086 is offline   Reply With Quote
Old 02-06-2007, 12:26 PM   #7
I was looking at the links of the chain closely and the chain seems to be ok. I am pulling the rear carrier out today finally and going to see if I can get the bearings out myself. I have the new tires on it and it looks a lot better now. I'm debating on just selling it after I fix it because my g/f wants another polaris with an automatic since she doesn't like the clutch on the warrior. I called the local yamaha dealership and they said that the value on it was $2,400-2,500 depending on the condition. I'm debating on just putting it on ebay this weekend.
Old 02-06-2007, 04:58 PM   #8
:?: :?: Maybe I should check on the trade in value of my 2. $5000 would be a great down payment on a 700 Grizzly. Ebay you are lucky to get $1400 these days.
2007 700 Grizzly
Old 02-06-2007, 11:28 PM   #9
Well I don't have to replace any bearings now.... I just sold it to a friend of mine tonight for $2,100 without the extra wheels and tires I have for it. I still have a set of rear stock yamaha wheels with maxxis tires(22x11x9) mounted on them and an extra set of holeshot lookalikes(20x11x9) for sale. Guess I'll post them in the for sale forum if my buddy doesn't buy them.
how to replace axle bearings yamaha warrior
yamaha warrior rear axle removal
yamaha warrior axle bearings
how to change warrior axle bearings
96 warrior axle bearings
96 warrior axle removal
yamaha warrior rear axle bearings
yamaha warrior 350 how wide rear axle
2001 yamaha warrior rear axle bearing carrier compatible
how too replace axel berings in yamaha 350 warrior
how to replace rear bearings on a warrior
rear carrier for 1999 yamaha 350 warrior
Replacing rear axle bearings DavidBeebe Yamaha YFM660R Raptor (2001-2005) 6 07-01-2008 02:10 PM
Removing rear axle bearings??? sjd78 Yamaha YFM660R Raptor (2001-2005) 7 08-26-2005 05:59 PM
Rear axle bearings Wheeljack Yamaha YFM350 Raptor/Warrior ('87-Present) 4 02-21-2005 08:09 AM
How hard is it to install rear axle bearings?? cobbstg2wrx Yamaha YFM660R Raptor (2001-2005) 10 09-03-2003 07:51 PM
How hard is it to put axle bearings in a Raptor? PLease help Yamaha YFM660R Raptor (2001-2005) 2 09-30-2002 02:16 PM
