Warrior will not start with push button HELP? - Yamaha ATV Forum
This is a discussion on Warrior will not start with push button HELP? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I just bout a 92 warrior that will run if bump started. will not start using the push button. I am getting power however the ...
Old 01-10-2007, 07:05 PM   #1
View davefan1516's Photo Gallery(0)
Default Warrior will not start with push button HELP?
I just bout a 92 warrior that will run if bump started. will not start using the push button. I am getting power however the Green light does not come on. I am doing a tune up as the quad sat for a while before i boutht it. New battery, new oil,new gas new air filter new spark plug. Anything else i should do? Help me out with getting it started.
like i said i can get pulled up to speed then pop the clucth and it starts. I just would like to beable to start it on my own.
THanks Dave
davefan1516 is offline   Reply With Quote
Old 01-11-2007, 05:30 AM   #2
Warrior's Avatar
View Warrior's Photo Gallery(0)
Are you pulling the clutch in? Is it making any noise like the starter is getting power or clickingg from under the seat?
Cruz/Warrior
'04 CR250r
'09 YFZ450r
, Stolen
'09 KTM 505 SX
Warrior is offline   Reply With Quote
Old 01-11-2007, 10:12 PM   #3
yes i am pulling the clucth in. I have to put a new battory in the quad so untill then i will not know it it is makeing any noice. thanks
Dave
Old 01-13-2007, 07:11 PM   #4
View wie1086's Photo Gallery(0)
try jumping across the 2 sides of the solonoid and see if it does anything. If that doesn't work, try jumping from the battery pos. to the starter. 3 things it could be, but not limited to; starter, starter solonoid or starter button. If the solonoid jump gets you something, try flushing out the starter button -there is a hole in the bottom.
Let us know what happens
2007 700 Grizzly
2000 Warrior-traded in
2001 Warrior-traded in
http://ohiomafiariders.com/images/logos/omruserbar.gif
wie1086 is offline   Reply With Quote
Old 01-13-2007, 09:18 PM   #5
ok thanks going to work on it now. i will let you all know.
Old 01-15-2007, 01:22 PM   #6
View Jasonp's Photo Gallery(0)
I would check the main fuse, which I believe is just before the starter solonoid under the rear fender. I know I had that same trouble.
1998 Warrior. JE 366cc, Mega .450", HD TI valve springs, DR P&P head, DR flywheel, KW SS Oversized valves, TM36-68 Carb, Dyna DFS7P, HD Barnett clutch springs, Earl's custom oil cooler/big bear setup. AC Bumpers, Holeshot's with .190 rims.
Jasonp is offline   Reply With Quote
Old 01-15-2007, 07:25 PM   #7
Ditto -I forgot that one
2007 700 Grizzly
Old 01-15-2007, 09:59 PM   #8
i changed the battory, cleaned all the contacts and did a tune up. now it works. Thanks
Old 01-16-2007, 08:24 PM   #9
thanks for sharing the final outcome
2007 700 Grizzly
Old 03-26-2011, 10:31 PM   #10
View Amfreeman's Photo Gallery(0)
I have the same issue in my 03 warrior. No spark with the electric start what did u do to clean the contacts and which one. It will also start on it's onwn when it's warmed and been running for a while I don't c what changing the battery would do what does that have to do with my lack of spark unless ur battery was totally shot
Amfreeman is offline   Reply With Quote
yamaha warrior electric start wont work
350 warrior only elctric starts when warmed up
yamaha warrior 350 wont start with push button
why does my 6 speed warrior not fire
350 warrior wont start with start button
why does my 92 yamaha only tick when i push the start button
2000 warrior 350 not starting
my warrior 350 gas new battery and power by wont turn over
96 warrior 350 electric start will not work
2001 yamaha warrior 350 6 speed. start button
92 yamaha warrior oil
1998 yamaha warrior starter button is not working it wint turn over
Warrior won't start when I push in button shipdadip Yamaha YFM350 Raptor/Warrior ('87-Present) 16 10-25-2012 03:45 PM
RAPPY 660 wont start on it's own, only on push/tow, HELP!!! grphicdeziner Yamaha YFM660R Raptor (2001-2005) 46 07-05-2007 12:39 AM
start button keeps shorting out??? JBPLAYFZ450 Yamaha YFZ450/450R (2004-Present) 3 01-14-2007 09:06 PM
start button scaryfast450 Yamaha YFZ450/450R (2004-Present) 5 08-29-2005 06:34 AM
Shee won't start unless I push start it Traxxastampede Yamaha YFZ350 Banshee (1987-Present) 7 03-19-2003 09:52 PM
