BAD STARTER? - Yamaha ATV Forum
BAD STARTER?
This is a discussion on BAD STARTER? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I JUST FINALLY GOT THE WARRIOR RUNNING - BUT YESTERDAY THE SOLENOID WOULD JUST BUZZ WHEN I TRIED TO START THE ATV. CHECKED ALL OF ...
Old 10-09-2006, 10:27 PM   #1
View warrior1027's Photo Gallery(0)
Default BAD STARTER?
I JUST FINALLY GOT THE WARRIOR RUNNING - BUT YESTERDAY THE SOLENOID WOULD JUST BUZZ WHEN I TRIED TO START THE ATV. CHECKED ALL OF THE CONNECTIONS, CLEANED AND SANDED THEM. STILL JUST BUZZES. TOOK THE STARTER OFF AND CHECKED THE CONNECTION. BATTERY WAS CHARGED OVERNIGHT AND IS 1 MO. OLD. I'M SURE THATS NOT THE PROBLEM.CAN I DIRECT CONNECT THE POSITIVE SIDE (battery)TO THE TERMINAL ON THE STARTER AND CONNECT THE STARTER CASE TO THE NEGATIVE SIDE. SHOULD'NT THE STARTER SPIN. NOTE: I'VE GOT THE STARTER OFF OF THE ATV. iT WON'T DO ANYTHING. ALSO, WHEN I JUMPED ACROSS THE(NEW) SOLENOID IT JUST SPARKED. THE STARTER DIDN'T MOVE.----- IS THE STARTER BAD????? ALL THE CONNECTION ARE CORRECT AND TIGHT.
warrior1027 is offline   Reply With Quote
Old 10-09-2006, 10:37 PM   #2
View Unlukky's Photo Gallery(0)
Take the starter cap off and check to see if the gears are messed up or if you see any obvious reasons why it is locked up.
Unlukky is offline   Reply With Quote
Old 10-09-2006, 10:44 PM   #3
View yamarider350's Photo Gallery(0)
sounds like a bad starter to me, but you can't say for sure without taking it apart and checking it out.
yamarider350 is offline   Reply With Quote
Old 10-09-2006, 10:54 PM   #4
I HAVE ALREADY TAKEN THE STARTER APART. THE PARTS LOOK OK BUT IT TURNS FAIRLY HARD. I CLEANED THE PARTS AND PUT IT BACK TOGETHER. JUST SEEMS HARD TO TURN. IT IS TOGETHER RIGHT.
Old 10-09-2006, 11:05 PM   #5
The starter should spin freely. If you take it to an auto parts store like Advance Auto they should be able to test it for you. You could also just hook it up directly to a battery charger (20+ amps) and see if it spins.
Old 10-14-2006, 12:38 PM   #6
View wie1086's Photo Gallery(0)
I would try jumping it and see if it cranks ok. Use a car if necessary, just dont leave it hooked up very long (connect and crank) If it does -bad battery. Sometimes new ones can be faulty. Solenoid chatter is usaully not enough current.
Your starter should be a little stiff due to the oil seal.
2007 700 Grizzly
2000 Warrior-traded in
2001 Warrior-traded in
http://ohiomafiariders.com/images/logos/omruserbar.gif
wie1086 is offline   Reply With Quote
Old 10-16-2006, 12:57 AM   #7
It was a short caused by the starter wire being up against the exhaust pipe and melting causing a short! Oh well I got a new starter anyway. The old one was real tired! Thanks for the help
2000 yamaha kodiak 400 starter should it spin tough
2004 yamaha kodiak 450 starter won't engage
yamaha kodiak 400 starter problems
how to check a starter solenoid on a yamaha kodiak 400
warrior bad starter
2001 yamaha kodiak starter relay
1999 yamaha kodiak starter just spins
how to connect starter relay 2003 kodiak 450
how to take starter off kodiak 400
starter relay yamaha kodiak 2004 which side is positive
yamaha kodiak starter spinning
2000 yamaha kodiak 400 truck solenoid
Starter One way YamahaBanshee#1 Yamaha YFM660R Raptor (2001-2005) 2 03-22-2005 05:44 PM
starter one way or ? jmoney Yamaha YFM660R Raptor (2001-2005) 2 01-06-2005 07:17 PM
Looking For Starter FroggF350 Yamaha YFM660R Raptor (2001-2005) 0 12-09-2004 10:10 AM
YFZ 450 Starter same as warrior starter? Yamaha YFZ450/450R (2004-Present) 1 07-10-2004 12:39 PM
Starter Jet?? The J Yamaha YFZ450/450R (2004-Present) 6 09-27-2003 11:38 PM
