06-06-2005, 06:27 AM
O- ring or non o-ring, that is the question!
Is there a reason not to go with the non o-ring chain? For the cost you can buy 2-3 of them before a single o-ring chain. Any thoughts on the non o-ring? Just wondering before I spend the money!
06-06-2005, 11:40 AM
Go with the O-Ring (or x-ring). If you get a non-o-ring chain wet, it will rust in the pinholes and joints, get stiff and not move smoothly making the chaing more likely to snap and crack open your case. It will cost you a lot more to patch up an engine case than the amount it will save you going without o-rings
06-26-2005, 05:35 PM
Non o-ring chains work better in sandy conditions,just lube it often(wax)and it will not rust
06-26-2005, 08:55 PM
Non- oring chains will give you a very very slight increase in power, i run non-oring, and will never run another o-ring . They are too expensive 100 dollars for a freakin chain is insane, i can buy 4 non oring chains for that price and ride longer on them.
2001 black/white/yellow warrior
Yoshimura and edelbrock carburator installed.
Too much to list!!
06-26-2005, 09:09 PM
Yep
06-27-2005, 07:55 AM
I need o-ring or x-ring chains up here
me and my friend both had normal chains and we both broke them and both broke are engine case
Need a dirt bike :(
06-27-2005, 10:24 AM
I bought a Parts Unlimited X-ring chain and it was just has cheap as a regular chain. It seems to be holding up better then a non oring chain too.
Old Enough to Know Better but Still Young Enough not to Care.
06-27-2005, 01:03 PM
Non-O-ring chain = sand and close MX
O-ring chain = everywhere else
TRX450R and 03 WARRIOR
"I'd rather trust a country man than a towns man." >Genesis "Lamb Lies Down on Broadway"
"Let us learn to show our friendship for a man when he is alive and not after he is dead."
>The Great Gatsby
o ring chain vs non o ring, o ring vs non o ring chain, o-ring chain vs non o-ring chain, o ring or non o ring chain for banshee, o ring chain vs non o ring chain, o ring vs non o ring chains, o-ring chain vs non, oring chain versus none oring, o ring vs non o ring chains motorcycle, o-ring chain vs non o ring atv, atv o ring chain vs non o ring, non o-ring vs o-ring motorcycle chain
