Cracked intake boot - Yamaha ATV Forum
post #1 of 14 Old 05-08-2005, 04:07 AM Thread Starter
Cracked intake boot
I was wondering if anyone else has had trouble with their intake boot cracking. Mine has just cracked for the second time and it's only a '04. Isn't this unusual for these to be doing this? Especially on a Warrior that is only 1 1/2 years old? Is there anything to look for that could be causing this? The first time I had cracked uppper motor mounts too which I suspected caused the problem the first time but this time they aren't cracked. I'm also worried too now because I was riding it at the dunes the last time I had ridden it and worried the the motor sucked in a ton of sand. Should I be thinking about taking the motor apart and checking for sand? Man this is frustrating, I wanna ride!!!!!
04 Warrior
Smuggles is offline
post #2 of 14 Old 05-08-2005, 08:22 AM
Warrior King's Avatar
Send a message via MSN to Warrior King
Check all your motor mounts and make shore there tight, also check to make shore ur crab is on tight.
Boots to wear and crack over time, but having gone threw 2 on a 04 isnt right
about taking apart ur motor....its better safe then sorry, one good check you can do is take off you carb and boots and every thing so that ur right on the intake to the head and feel around there and check for any grim or dirt, if there is some then you might want to start taking some things apart
Need a dirt bike :(
Warrior King is offline
post #3 of 14 Old 05-08-2005, 12:06 PM
WBWarrior's Avatar
Send a message via AIM to WBWarrior
Does it sit in the sun all the time? Maybe the rubber is dry rotting. As for suckin sand in the motor, why do you you think it did? Did you run without a filter or something? It cant just get sucked in there.
03 Warrior~~~~sold
05 YFZ450~~~sold
Searching for another bike
WBWarrior is offline
post #4 of 14 Old 05-08-2005, 12:24 PM
I wouldnt worry about ripping anything apart to check for sand. Take a look at the carb while changing the boot and make sure its clean. As for sand getting in the motor. Technically whats done is done. You had an air leak. If it sucked in sand. It Sucked it into the piston and cylinder area and spit it out the exhuast. If it damged any in there theres nothing you can do about it.
If its runnen fine now It probbably wil for some time. But you may have shortened ring life somwhat..............I wouldnt worry about it.
Jstcriusen is offline
post #5 of 14 Old 05-08-2005, 12:37 PM
WBWarrior's Avatar
I agree with what Jstcriusen said. I didnt even realize that it cracked in th dunes. Guess I wasnt thinkin.
03 Warrior~~~~sold
05 YFZ450~~~sold
post #6 of 14 Old 05-08-2005, 01:25 PM
Send a message via AIM to badrider Send a message via Yahoo to badrider
when i first got my quad it had a cracked in take boot.. but after i got the new one on it never did it again. so far
i have a 1998 warrior with new pro circuit t4
badrider is offline
post #7 of 14 Old 05-08-2005, 02:36 PM
my 250r had the same problem, just replace it, better to be safe then sorry...go to www.yamahaoftroy.com one for my 250r was only like 35 bucks...
banshee19 is offline
post #8 of 14 Old 05-08-2005, 06:35 PM Thread Starter
I already ordered one off ebay for 32. It stays in the garage when I'm not using so the sun doesn't get to it. I hope I can find out why two have cracked already. I suspect that the carberatur is may be sitting to far back from the engine perhaps. I'll have to take a look when I take it apart.
04 Warrior
Smuggles is offline
post #9 of 14 Old 05-08-2005, 07:21 PM
I think they can be put on upside down i had one crack and it was on upside down. I am not positive of this but my buddys was on different than mine and when i got a new one i never had another problem.
easy101 is offline
post #10 of 14 Old 05-09-2005, 11:14 AM
Most cleaning prducts eat that rubber, especially engine cleaner. My orig boot finally cracked after 10 years, but I didn't shine the bike up much.Too busy riding.
1991 Warrior-Blue,Chameleon tank/fairing
Dyno-Jet,Uni filter, custom intake/ airbox
Custom tunable exhaust
Handmade aluminum skid, rear skid, stainless front bumper, reinforced frame, 1.25" tube rear frame section,
warrior91 is offline
post #11 of 14 Old 05-11-2005, 09:31 PM
I have replaced a few of them over the years. Worst thing is trying to tighten or loosen the 2 nuts between the carb and boot while jetting. Take the time to hold the carb while wrenching on the nuts. Most of us let the boot twist a little to hold the slack when we tourq the nuts. guilty
87,88,91,97Warrior
04KFX
03 S-10 Crewcab
Quad82 is offline
post #12 of 14 Old 05-12-2005, 11:03 AM
I had just replaced mine yesterday, and low and behold I had installled it upside down, and that is what caused it to crack. the o ring goes toward jug, and the arrow points up, you will do fine and they are correct to not let the nuts twist the boot while tightening it. good luck...
93 warrior stock, being built ground up right now!!!! pics soon!!!!3/3/05
xjnuttier is offline
post #13 of 14 Old 12-17-2012, 10:53 AM
I know this thread has been dead for years, but I've had this carb boot ripping problem too, if I cut out the rubber center and welded a piece of metal in its place, could it do any harm??
Jwhite12 is offline
post #14 of 14 Old 12-17-2012, 09:36 PM
They are rubber for a reason. You want the carb to be able to flex. If you make it solid you might end up breaking the carb ears or something more. These boots last for years if installed properly and all motor mounts are tight and in good shape. If they keep breaking then there is an underlying problem causing it.
2002 Raptor 80: Big bore 3mm over, full FMF pipe, etc.
2005 Raptor 350: FMF Power Core 4, Uni clamp on filter.
2002 Raptor 660 Wiseco 9.9:1 piston, K&N filter and Full FMF Exhaust
MidwayUSA is offline
Intake boot question Mad Cow Yamaha YFM660R Raptor (2001-2005) 5 01-01-2008 03:09 PM
ESR intake Vs Ron Woods intake yamarider Yamaha YFZ450/450R (2004-Present) 4 05-01-2005 06:08 PM
intake boot mods velocity/swirl sto'stimemachine Yamaha YFM660R Raptor (2001-2005) 8 04-11-2005 04:22 PM
Pro-flow intake VS RW Airbox Intake, which is better for MX? TRUTH Yamaha YFZ450/450R (2004-Present) 11 01-30-2005 07:52 PM
Boot fit pearsth Riding Gear/Accessories 1 09-12-2003 10:56 PM
