Still cant get pivot bolt out of swingarm!! - Yamaha ATV Forum
This is a discussion on Still cant get pivot bolt out of swingarm!! within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; ok, well i know this is a usual problem on most quads. I was lucky with my tecate and my 400ex. But this warriors wont ...
Old 05-04-2005, 08:48 PM   #1
View empty-wallet's Photo Gallery(0)
Default Still cant get pivot bolt out of swingarm!!
ok, well i know this is a usual problem on most quads. I was lucky with my tecate and my 400ex. But this warriors wont budge AT ALL.
I was out there beating the crap out of it and it wont budge. I got some PB blaster and loaded the SOB up, tried it again. Then let it soak about 1-2 hrs and hit the crap out of it...again no budge. THen i took a propane torch and heated it up pretty damn good and beat it until the nut on the end of the pivot bolt started to squash. Im out of ideas???? IM trying to part this thing out and cant get the swingarm separate from the frame. Guess last resort is to sell as a whole
www.myspace.com/kylejandura
empty-wallet is offline   Reply With Quote
Old 05-04-2005, 10:36 PM   #2
View FMFWarrior21's Photo Gallery(0)
Did you try loosening it with an impact wrench?Mine siezed up pretty good and an impact wrench loosened it right up and it popped right out.
www.yfm350central.com
Blingstar-nacs-fmf-twin-air-ac-kenda-durablue-moose-dynojet-renthal-RK-SRP-UPP
FMFWarrior21 is offline   Reply With Quote
Old 05-04-2005, 11:53 PM   #3
View WarriorRacer#13's Photo Gallery(0)
Yeah, def. try using a airgun on the other end and get it to spin. Once you get it to spin, it should come out. I know when I ot mine, I had to use a long punch and put it down in the cente rof the pivot bolt and beat the hell out of it with a 3 pound sledge, even after spinnning it. But it WILL come out...you just gotta get a bigger hammer
WarriorRacer#13 is offline   Reply With Quote
Old 05-05-2005, 12:23 AM   #4
View 440ex4me's Photo Gallery(0)
HAve you tried a sawzall?
I had to on this one.
Sometimes you dont have any choice but to cut it out. I tried everything you did plus some others but had only one thing that worked.
Good luck and have a few extra blades since you may need them.
Ole reliable 440ex with too much to list.
Off Road NJ http://www.offroadnj.com/ ATV assoc in NJ fighting for our right to ride!
CHECK IT OUT !!!
Exriders.com SUKS SUKS SUKS SUKS FO to those losers and their BS "inner circle". Why be censored by a bunch of middle aged fart jack arses. FRIG EM. Any questions? :)
440ex4me is offline   Reply With Quote
Old 05-05-2005, 07:49 PM   #5
the bolt will turn freely...just wont budge comming out at all
I was hoping i wouldnt have to cut the thing but i guess i dont really have a choice....also i dont have any air tools. I have access to them, but no truck to get the frame there.
It would probably come out if i could get a air chisle on there and put a punch bit on the end and just pound at it to free the rust and what not.
Old 05-11-2005, 01:12 PM   #6
Pounding the damn thing with the chisel could work but most likely would just mushroom the bolt like what happens when you really pound it with a sledge hammer.
Anyhow did you get it cut out yet?
CHECK IT OUT !!!
Old 05-11-2005, 10:00 PM   #7
View Quad82's Photo Gallery(0)
Tourches. I don't belive you can get it ALL hot enough with a propane one. Like was said eariler, SawZal. Start on the threaded end first. you might get lucky and only have to cut the mushroom end off. If the nut squished I would bet the boly flexed a little too.
87,88,91,97Warrior
04KFX
03 S-10 Crewcab
Quad82 is offline   Reply With Quote
Old 05-18-2005, 09:51 AM   #8
View Dirt Merchant's Photo Gallery(0)
heh had the same problem.. would spin with your fingers, but would not come out..
The bolt is inside a sleeve that gets crud and holds it in there..
Remember this "IF YOU BEAT IT HARD ENOUGH IT WILL COME OUT" We got the one out on the hybrid we are working on by way of a 50 lb maul and about 3 good hits.. pin shot out like a bullet...
By the way, throw that can of PB blaster away and invest in some KROIL, pb blaster wouldnt get this thing out, as soon as i put some kroil on it, it loosened right up... I have had hubs frozen to the axle that pb blaster and a big ass hammer wouldnt remove.. shot it with some kroil, 5 minutes later i could pull them off with my hands.. Its good stuff, but it stinks like
Jesse
Dirt Merchant is offline   Reply With Quote
Old 05-19-2005, 04:49 PM   #9
View badrider's Photo Gallery(0)
i am having the same problem. i have used 2 cans of that pb blaster stuff. and beat the hell out of it while using a impact wrench. it just dosent move. it sounds solid. but i am goin to try that kroil and see what that dose
i have a 1998 warrior with new pro circuit t4
badrider is offline   Reply With Quote
Old 05-19-2005, 06:55 PM   #10
View warrior91's Photo Gallery(0)
have you tried moving the arm up and down while beating? This could cause the pin to move out of a groove/lip holding it back. When in doubt get a bigger hammer!
1991 Warrior-Blue,Chameleon tank/fairing
Dyno-Jet,Uni filter, custom intake/ airbox
Custom tunable exhaust
Handmade aluminum skid, rear skid, stainless front bumper, reinforced frame, 1.25" tube rear frame section,
warrior91 is offline   Reply With Quote
Old 05-19-2005, 10:37 PM   #11
View WarriorBoss's Photo Gallery(0)
Had the same thing happen to mine. Needle bearing get wedged in with the sleeve and bolt. Only thing that got mine out was an air hammer.
Becareful, that pivot bolt costs 20 bucks and the lock nut was 4
97 Warrior
10:1
Uni
Stock Pipe no baffle
14-40 Gearing
22" ITP MudLites
WarriorBoss is offline   Reply With Quote
Old 05-23-2005, 07:43 AM   #12
i tried moving the swing arm while hitting the bolt but didnt do nothing. this thing is starting to make me furious . just gotta get that thing out then off for paint. ill just have to get the 5 pound sledge off retirement. haha
Old 05-23-2005, 02:46 PM   #13
View jakalwarrior's Photo Gallery(0)
I had to cut mine too. We spent several days on it and it got to the point that we were hitting it so hard my frame was flexing. Even after we got it out it became apparent no amount of beating would of ever gotten it apart, they were rusted together into one solid piece.
2 wheels: Y2k KX500 - 2002 YZ125 - 2012 ZX6R - 2002 VTX1800C - 1973 RD350
4 wheels: 2007 Raptor 700, 1994 Trailboss 250
jakalwarrior is offline   Reply With Quote
yamaha warrior 350 swingarm bolt
how to get a stuck pivot bolt out of a warrior swingarm
warrior 350 swing arm removal
cutting swing arm pivot bolt on warrior 350
which side does swingarm bolt come out of 350 warrior
does swingarm bolt thread into frame on 400ex
how to get warrior swing arm bolt out
warrior cutting swing arm bolt
how to remove pivot shaft from swingarm on 2001 yamaha warrior
cant remove swing arm bolt from a wr450f
cant get swingarm off ktm 1025
remove swing arm yamaha warrior 350
Frozen swingarm pivot bolt Towlieee Yamaha YFM660R Raptor (2001-2005) 7 04-18-2007 07:45 PM
Swingarm pivot bolt won't come out!!! Gomez 909 Yamaha YFS200 Blaster ('88-Present) 10 05-27-2005 03:41 PM
Swingarm pivot bolt blast94 Yamaha YFS200 Blaster ('88-Present) 5 11-02-2003 09:05 PM
BROKEN PIVOT BOLT ON SWINGARM??????????? BCRAPTOR Yamaha YFM660R Raptor (2001-2005) 8 03-26-2002 01:31 AM
Raptor Swingarm Pivot Bolt ? Jetstream31 Yamaha YFM660R Raptor (2001-2005) 2 01-16-2002 07:53 PM
