Warrior starting problems
This is a discussion on Warrior starting problems within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I have a 89 warrior. Ever since I got it, I've had trouble getting it to turn over. It struggles to turn the engine over. ...
Old 04-10-2005, 07:00 PM   #1
View 88fan's Photo Gallery(0)
Default Warrior starting problems
I have a 89 warrior. Ever since I got it, I've had trouble getting it to turn over. It struggles to turn the engine over. I replaced the starter, battery, solonoid. All it does when I go to first start it , sounds like the starter is just sitting there zinging away, then it starts to get some resistance, then it will start to turn the motor over. Once the motor starts turning over, it doesn't have a problem. It's just by then the battery is getting low from cranking on it for so long. Thanks.
89 Warrior
Dirt Devils
More Mods Coming Soon
88fan is offline   Reply With Quote
Old 04-10-2005, 07:03 PM   #2
Warrior King's Avatar
View Warrior King's Photo Gallery(0)
startor clutch? i am kinda unshure what you are discribing, but i say its in your startor....even though you said you replaced it...hmm
Need a dirt bike :(
Warrior King is offline   Reply With Quote
Old 04-10-2005, 09:15 PM   #3
View Quad82's Photo Gallery(0)
Does it sound like just the starter is turning or can you also hear it maybe turning a gear too? If the starter is turning and the motor isn't, the only thing left is the one-way driven gear. Easiest way but not the most sure is to pull the starter out and try turning the bigger gear that the starter turns by hand. If it turns both ways easy and doesn't engage you have a bad oneway. The best way to test it is to use a jackstand and prop the quad up on its side so as not to have to drain the oil. Pull the left side stator cover off. 4 Screws to pull the rewind or blanc cover off then 9 -8mm head bolts to take the stator cover off. Be careful not to missplace the 2 bushings/guides at about 10 and 2 oclock. If you are careful and use a mallet you can save the gasket. With the quad proped on its side you can turn it over like you were trying to start it. Pull the plug wire off so it doesn't start. You will see the big gear sticking out behind the flywheel. It's your oneway starter driven gear. If it's spinning with the starter but not turning the motor over, you need a new one. Need to use a flywheel puller. But that's another story. Keep us posted.
87,88,91,97Warrior
04KFX
03 S-10 Crewcab
Quad82 is offline   Reply With Quote
Old 04-11-2005, 08:54 PM   #4
yeh, just sounds like the starter is sitting there spinning away(zinging). Then eventually it catches and sounds like it's getting resistance. Then after awhile it will turn the motor over.
89 Warrior
Dirt Devils
Old 04-11-2005, 09:20 PM   #5
Starter clutch for sure....
06' Wolverine
Old 04-12-2005, 06:26 AM   #6
starter clutch? is that part of the starter or the engine?
89 Warrior
Dirt Devils
Old 04-12-2005, 06:57 AM   #7
View Ausie warior's Photo Gallery(0)
In the starter I think.
15, free and on top of the world (really on the bottom but any way)
warrior2002 casual MX machine
xr100 86, stock for all i know
xl250 86 custom pipe, rack, bars, shocks as soft as a....................
lt80 2002
Ausie warior is offline   Reply With Quote
Old 04-12-2005, 07:23 AM   #8
View 2000 YFM350X's Photo Gallery(0)
mine does the zinging thing every once and a while. But it will catch and start right up. I does it like once a month.
2000 White/Red Yamaha Warrior with just a few extras
88 GMC K1500- duals w/ 4" tips
2000 YFM350X is offline   Reply With Quote
Old 04-12-2005, 10:03 AM   #9
you have to pull the flywheel, the starter clutch is on a big gear behind the flywheel.
06' Wolverine
Old 04-12-2005, 11:00 AM   #10
View WarriorRacer#13's Photo Gallery(0)
The starter clutch is actually a one-way bearing that's bolted to the flywheel. The big gear that you see behind the flywheel sits inside the bearing and is what the bearing actually catches. The one-way bolts have to be drilled out to get it off the flywheel(they are shot peened on the back side to keep them from ever loosening) It's a pretty pricey part, something like $80. I had to replace the one on my first Warrior. If it's slipping like 2000 YFM350Xs, it will eventually completely fail and the quad won't start at all, much like you're experiencing 88fan.
WarriorRacer#13 is offline   Reply With Quote
Old 04-13-2005, 09:27 PM   #11
is it possible to get a pull starter from an older warrior and put it on my 89? I just want a backup in case of a dead battery or something.
89 Warrior
Dirt Devils
Old 04-14-2005, 08:57 AM   #12
Yes, but don't forget to install the decompression setup.
06' Wolverine
Old 04-14-2005, 12:52 PM   #13
For the pull start setup you need the pull starter case with rope, a 4flange crank adaptor. Unless you are pretty strong you also need the decompression lever on the head. I have both with and without the decompression lever. They both are useable but my kids can't pull the one over with out the lever. You can pick the recoil up off ebay for around $30 or so. I have a spare 4flage if you need it but sometimes when you buy the recoil you can get this part too if you ask.
87,88,91,97Warrior
04KFX
03 S-10 Crewcab
Old 04-14-2005, 12:53 PM   #14
I dont think you will need the decompresion, a friend runs his with nothing but pull start and hes only 5'6 140 pounds, its not that hard
Need a dirt bike :(
Old 04-14-2005, 06:38 PM   #15
Well, I took the starter off and the gear that the starter turns, I can turn it backwards(towards the rear of the quad) real easy. I can also turn it towards the front of the quad too, not as easily though. So, does that mean my one way that you referred to is bad? If so, what all is involved with replacing it. How much are the parts, cause I'm pretty mechanical and can do the work myself if I know what all's involved. Thanks, everyone.
89 Warrior
Dirt Devils
Old 04-14-2005, 10:54 PM   #16
The one-way bearing is like $80. You just pull of the stator side cover, pull off the flywheel and the one-way s right there. It's actually bolted to the flywheel, but the bolts are side-punched to keep them from EVER turning out, so you canNOT get them out. You have to drill the heads off. Then put on the new bearing, put in the bolts, side-punch them and reassemble. If you can get the sidecase off without tearing the gasket, all you need is the bearing and the bolts. But I'd go on and get a gasket, just to be safe, it's only a couple bucks. Th eonly specialty tool you have to have is the flywheel puller, but if you take the quad to a shop with the side off and everything, they may do it for you for next to or nothing.
warrior starting problems
what cause the starter to fail on my yamaha warrior
2003 yamaha warrior 350 starting problems
warrior trouble starting
yamaha warrior starting problems
yamaha warrior starter problems
96 warrior starts hard
yamaha 200 atv turns over but won't start. starts with recoil
warrior hard starting
89 warrior 350 starter spins for a while then slowly catches
96 yamaha warrior 350 turns over really hard
starter motor location on 88 warrior
starting problems aaront2 Yamaha YFM700R Raptor (2006-Present) 3 08-31-2005 11:37 AM
has anyone ever had problems with a 96 warrior starting? MIKEMOKAS Yamaha YFM350 Raptor/Warrior ('87-Present) 3 04-18-2005 07:24 AM
starting problems jsl2003atv Yamaha YFZ450/450R (2004-Present) 2 04-05-2005 04:05 PM
starting problems Raptor_Racer_06 Yamaha YFM660R Raptor (2001-2005) 4 09-24-2004 09:35 PM
