Tips & Tricks for Front Wheel Bearing Replacement? - Yamaha ATV Forum
This is a discussion on Tips & Tricks for Front Wheel Bearing Replacement? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I think the dumb bastid that owned this quad before me used red locktite on the backing plate(disc) bolts and they are not wanting to ...
Old 02-04-2005, 10:15 AM   #1
View skirider's Photo Gallery(0)
Default Tips & Tricks for Front Wheel Bearing Replacement?
I think the dumb bastid that owned this quad before me used red locktite on the backing plate(disc) bolts and they are not wanting to come out at all.
Will applying the heat necessary to break the locktite bond warp or damage the connected parts?
Appreciate the help!
ski
skirider is offline   Reply With Quote
Old 02-04-2005, 10:25 AM   #2
Yes Heat is the BEST way to get locktite loose. Be patient let the heat absorb through the bolt before your try...
Old 02-04-2005, 10:30 AM   #3
Thanks digger!
You get my PM on the pipe?
Old 02-04-2005, 12:07 PM   #4
View WarriorRacer#13's Photo Gallery(0)
You don't have to take the disc off to replace the front wheel bearings. But yes, heat will help break them loose, as will putting penetrating oil on them and letting it soak for a day or so.
WarriorRacer#13 is offline   Reply With Quote
Old 02-04-2005, 12:12 PM   #5
Really on the removal? From what I had seen in the manual it looked like that had to be removed? Explain it to me if you can, I'd really appreciate it!!
Old 02-04-2005, 01:19 PM   #6
Well, I dunno. But on the ones I've replaced, I'm almost positive that I didn't have to take the rotor off the hub. I just replaced a set last summer in a Warrior. You have to drive them out from opposite sides, of course (fromt he back for the outside ones and from the front for the inside ones) but I don't think I've EVER had the rotors off the hubs on any of the Warriors I've had (a total of six) and I've changed prolly four sets of wheel bearings.
Old 02-05-2005, 07:43 PM   #7
View Corn55's Photo Gallery(0)
No, you dont need to take the rotors of, maybe if you have like an 87 or around there they could be different, but newer ones don't. I would get a clymer manual easiest way for it to be explained to you, but wr13 is right.
1996 FST/HSD 435 Warrior
Soon to be 50" at both ends
"If it has tits or tires it costs me money."
Warrior parts and other misc for sale, http://www.bluetraxx.com/phpBB/viewtopic.php?t=70321
Corn55 is offline   Reply With Quote
how to change front wheel bearings on 700 rhino
yamaha warrior wheel bearing change
how to change the front wheel bearings on a yamaha 350 warrior
wheel bearings yamaha warrior
removing front hub on yamaha 350 warrior youtube
how to replace front barring on 2007 rhyno 450cc yamaha
how to install front hub bearings on 2004 yamaha 350 warrior
how to change front wheel bearings on a raptor660
replacing front wheel bearings vmax
how to do warrior 350 wheel bearing
front wheel hub bolts for 01 yamaha warrior
changing front wheel bearings on yamaha kodiak
front wheel bearing removal jbstacy Yamaha YFM350 Raptor/Warrior ('87-Present) 1 10-04-2007 08:11 AM
blown front wheel bearing help jeeper33 Yamaha YFM660R Raptor (2001-2005) 2 07-13-2005 01:33 PM
Front wheel, swingarm and rear shock linkage bearing #'s! jerstilly Yamaha YFM660R Raptor (2001-2005) 3 11-27-2004 12:44 PM
tips/tricks to applying graphics petedog9 Yamaha YFM660R Raptor (2001-2005) 4 06-26-2003 04:29 PM
Front wheel Bearing replacment... 96YZF350 Yamaha YFZ350 Banshee (1987-Present) 2 12-06-2001 08:08 PM
