Oil Cooler, how many installed it & was it worth it? - Yamaha ATV Forum
post #1 of 15 Old 09-11-2004, 09:38 PM Thread Starter
I'm thinking about adding the oil cooler to my warrior but before I get into all the work I was wondering if it made any difference and did you have any problems with the installation. Thanks!
rockhound is offline
post #2 of 15 Old 09-11-2004, 10:40 PM
Send a message via AIM to RxRaptor02
I have never done this.. but yes it does work.
If you look how specwarrior did his oil cooler install it was much easier than having to remove the side case and drill. his cooled the oil good.
if you do the oil cooler like he did just make sure you have good protection of the oil lines. and that would be the same for the other hookup as well. you dont want to get out and have a stick or rock hit a line and brake it.
----Michrider----
----Hatfield/Mccoy veteran '05----
-----Tug Hill veteran '03 '04------
raptor, lakota, KDX200
RxRaptor02 is offline
post #3 of 15 Old 09-12-2004, 12:11 AM
Send a message via Yahoo to SpecWarrior
Regardless of how you choose to install a cooler, it is a good idea to have one. It isn't AS neccessary with an internally stock motor, but it still helps on those hot days ESPECIALLY if you are operating alot at high revs and low speeds (hill climbing, dunes, etc...).
This isn't something where you will notice a performance gain, but will help prevent overheating and performance loss.
-=Tug Hill 2004 Veteran=-
2004 YFZ450.LE
*Big Gun Racing Exhaust (Full system ceramic coated)
*SRP Metals steering dampner
*Custom Aluminum ORV Plate
*Dynojet Jetted
*Shark Teeth Graphics
*AC Racing Nerfs
SpecWarrior is offline
post #4 of 15 Old 09-12-2004, 11:44 AM
Warrior King's Avatar
Send a message via MSN to Warrior King
i did it just for my high compression pistin, i went with mascmans style, workes great!
like spec said u dont get any more performance, but it will help ur bike perform longer, and improve the life of ur motor
Need a dirt bike :(
Warrior King is offline
post #5 of 15 Old 09-12-2004, 03:44 PM
Can you post a guide or something spec? Just curious how you did yours.
Learning to burn one day at a time.
2005 Raptor 660
2005 Raptor 350 (wifes)
Blackrose is offline
post #6 of 15 Old 09-12-2004, 06:47 PM
this is mascmans way and if you look at an older big bear 350 there is an oil cooler on it. There is a cover attached where the normal oil filter cover goes. It has fittings on it that will go to your cooler and then return back to the cover. You can go to a yamaha dealer and look on the fish for part numbers (however fish is spelled ) You can order new parts or find some on ebay, but a lot of other are looking too. I myself have the mascmans style cooler, I like it so far but either way will work.
TRX450R and 03 WARRIOR
"I'd rather trust a country man than a towns man." >Genesis "Lamb Lies Down on Broadway"
"Let us learn to show our friendship for a man when he is alive and not after he is dead."
>The Great Gatsby
dirtdevil is offline
post #7 of 15 Old 09-12-2004, 09:47 PM
Anyone who needs a Big Bear oil cooler setup, I have a used one to sell. Contact me privately
06 700R
LotusPosition is offline
post #8 of 15 Old 09-15-2004, 06:53 AM
Anyone have pics of that Big Bear oil cooler set up on a Warrior. There doesn't look like there would be enough room for the Big Bear oil pump cover, being so tight next to the stator on the Warrior. I'm there if it can be done.
2001 Warrior,works shocks w/ext.rez,renthal bar,razr 2's on douglas,k&N,Powroll air box lid,nerfs,ac bumber,ceet graphics,park block off,msr handles, dura blue spacers f&R,noss machine billet, modquad billet,steering dampner,e-series exhaust, sidewinder ti-moly 13/41, sprockets, t-moly chain. Magura hydraulic clutch, EBC clutch disc/springs.
TheQuadFather is offline
post #9 of 15 Old 09-15-2004, 04:55 PM
Here is one picture of it.
2004 YFZ450.LE
*Dynojet Jetted
*AC Racing Nerfs
post #10 of 15 Old 09-15-2004, 08:57 PM
Thanks man, that's too cool, I don't know why I haven't seen that before. I like it.
post #11 of 15 Old 09-15-2004, 10:35 PM
This is my set up, just needed some JB weld, tap, and drill. Not too tough a mod and much cheaper than the big bear way.
>The Great Gatsby
post #12 of 15 Old 07-08-2014, 05:23 PM
for some reason I cant see no pics would any of you guys want to send then to me?
kobie is offline
post #13 of 15 Old 07-09-2014, 09:47 AM
In 10 years things change, the pictures were hosted on a server that no longer exists.
post #14 of 15 Old 03-10-2015, 05:49 PM
Sorry To Jump In On This thread but I'm in need of more info on the oil cooler mod for the Raptor warrior ATV. I have a question about your oil cooler mod on Step 6 it says to put putty in the galley between the holes witch holes in the galley is it talking about. the two holes we just drilled or the galley hole in the inside and the hole we drilled to line up with the little galley hole.
BobbyB01 is offline
post #15 of 15 Old 03-10-2015, 05:50 PM
BobbyB01 is offline
oil cooler add on Melon Yamaha YFM660R Raptor (2001-2005) 6 11-22-2007 10:15 AM
is it worth using an oil cooler? onebadsierra Yamaha YFM350 Raptor/Warrior ('87-Present) 8 04-06-2005 10:03 PM
Oil cooler installed: VelociRaptor350 Yamaha YFM350 Raptor/Warrior ('87-Present) 21 02-20-2005 10:23 AM
oil cooler babb_raptor Yamaha YFM350 Raptor/Warrior ('87-Present) 12 08-23-2003 01:04 PM
Oil Cooler Warrior548 Yamaha YFM350 Raptor/Warrior ('87-Present) 1 08-07-2003 09:20 PM
