headlights not working - Yamaha ATV Forum
post #1 of 14 Old 09-08-2004, 11:44 AM Thread Starter
Send a message via MSN to madriding1
My headlights quit working and at the same time my neutral light and electric start wont work... any ideas?? wiring looks good.. Thanks again in advance....
Nothing left to do but SMILE, SMILE, SMILE!!!!
madriding1 is offline
post #2 of 14 Old 09-08-2004, 12:07 PM
Send a message via AIM to zuzzu
get new bulbs...
zuzzu is offline
post #3 of 14 Old 09-08-2004, 12:20 PM Thread Starter
hahahaha.... thats not it but thanks anyway!
post #4 of 14 Old 09-08-2004, 12:22 PM
Is your key off?
No really, check the connections at your battery. You might have a loose connection, bad ground, or even the fuse may be blown. If it is the fuse check for bare wires.
ucfwarrior is offline
post #5 of 14 Old 09-08-2004, 12:23 PM Thread Starter
battery is brand new...key is on...all connections tight and fuse not blown..Thanks
post #6 of 14 Old 09-08-2004, 12:33 PM
clean and check the handle bar switch...?
post #7 of 14 Old 09-08-2004, 01:18 PM
Send a message via AIM to Kahuna Send a message via MSN to Kahuna
It could be that there is a termninal loose somwhere. Is it making any sounds, or is the motor turining over? Check the fuses again, and If my memory is right, the is one under the hood somewhere.
-Kahuna
2002 Honda 400ex
Not enough to list.
Kahuna is offline
post #8 of 14 Old 09-08-2004, 01:31 PM
I know 1 time i had stock lights they got to hot & was not making good contact with the connector on the bulb, it had melted, so i had to scrape some plastic out of the way.
99'warrior wiseco piston .40, 430 web cam, kb valve springs,wbr4 silencer, noss performance k&n airfilter with outer wear, hayden oil cooler, dynojetted carb,prm skids, trail tech computer, works dual rate fronts, galfer brake lines, rad dual bearing carrier, durablue rear axle, renthal banshee bars,
schrok is offline
post #9 of 14 Old 09-08-2004, 01:40 PM
Warrior King's Avatar
Send a message via MSN to Warrior King
well if all thouse things all went at once, u have a bad batery wire maby lol
Need a dirt bike :(
Warrior King is offline
post #10 of 14 Old 09-08-2004, 01:42 PM Thread Starter
not making any noise at all..checked all fuses..I can short the starter solenoid and it starts right up but the headlilghts and nuetral light still dont come on.. think it could be the starter solenoid(relay)??? thanks for all your help... you guys are the best
post #11 of 14 Old 09-08-2004, 03:18 PM
It sounds like your starter switch is bad if it they still won't come on. will it shut the quad off? Pull it off of the bars and see if anythings wrong with it, or coroded.
-Kahuna
2002 Honda 400ex
Not enough to list.
Kahuna is offline
post #12 of 14 Old 10-04-2004, 03:59 PM
Send a message via MSN to justin's warrior Send a message via Yahoo to justin's warrior
bulbs
check ure wiring all the way from ure switch to ure battery and buy new bulbs
justin's warrior is offline
post #13 of 14 Old 10-07-2004, 05:57 PM
Is the wire on the left side of the motor under the shift lever/oil filter unplugged?
87,88,91,97Warrior
04KFX
03 S-10 Crewcab
Quad82 is offline
post #14 of 14 Old 10-08-2004, 08:04 AM Thread Starter
Got it fixed finally.... It was the wiring coming from my ignition switch.. was full of dirt and not getting a good connection.. Just wanted to thank everyone for their help
red headlights raptor0443 Yamaha YFZ450/450R (2004-Present) 7 06-06-2005 12:34 PM
Headlights? Blackrose Yamaha YFM660R Raptor (2001-2005) 3 01-30-2005 05:42 PM
headlights? mark311 Yamaha YFM350 Raptor/Warrior ('87-Present) 9 09-14-2003 01:48 PM
Headlights! stormanimal Yamaha YFZ350 Banshee (1987-Present) 3 07-26-2003 12:18 PM
red headlights? WhiteBrosRaptor Yamaha YFM660R Raptor (2001-2005) 7 02-20-2003 03:43 PM
