08-07-2004, 11:11 AM
Help! Warrior Valve Adjustment
I've tried to find sites to tell me how to adjust the valves in my '91 Warrior. I checked out the manual download on the YFZ site but everytime Adobe comes up the manual freezes and I can't look at any page BUT the first page. If anyone could sent me a website or anything to help me it would be highly appreciated. I would like to print out the few pages from the manual so that I could have them on file, but my computer freezes up if I try to print it or save it. If anyone could e-mail those few pages that would be even better!!! Thanx!
ducks_83@yahoo.com
 1991 Warrior
08-07-2004, 11:10 PM
This How-To is for helping you guys adjust you valves i know alot of people ask me how to do this so here goes.You will need to remove the gas tank and cover,hood,and front fenders.
Tools Needed:
10mm socket
Allen head socket (cant remember which size)
15mm wrench
flathead screwdriver
feeler gauges
small crescent wrench/ignition wrenchs/or needle nose pliars
(1)
First off remove the plastic cover are on the drivers side part of the motor.Also remove the black flathead plug on top of the stator cover. Use the 15mm wrench to turn the motor over until you line up a small T in the hole there is also an F dont get that confused with it.Taking the spark plug out will aid in turning the motor over
(2)
Secondly you take the valve cover off the intake side I like to do the intake side first then exhaust.Now that the cover is off back off the 10mm jam nut.A set of ignition wrenches or small needle nose or crescentwrench will help with this.After the jam nut is backed off (do not remove it) insert the feeler gauge in between the rocker arm an top of the valve spring.
Tighten the small square stud down until you can pull the feeler gauge out with a bit of a drag.(For the correct clearances look below)
(3)
Follow the same steps as 2 for adjusting the exhaust valve.
Clearances:
Intake:0.06~0.10mm or 0.00236~0.00394in
Exhaust:0.16~0.20mm or 0.00630~ 0.00787in
Well that wraps that up if you guys need any additional help PM me or get ahold of me on AIM.Its a little tricky at first but after that it becomes second nature.
www.yfm350central.com
Blingstar-nacs-fmf-twin-air-ac-kenda-durablue-moose-dynojet-renthal-RK-SRP-UPP
08-08-2004, 07:14 AM
One thing that I do to make my life easier when adjusting the valves is to leave the front fenders and hood on, and take the gas tank off by sliding it rearward. It is kind of a tight fit, but it can be done, and it saves you the trouble of pulling all that other stuff off.
'02 Raptor - CT Sonic Exhaust, ProDesign w/K&N and no lid.
Red '05 Grizzly 660
08-08-2004, 10:31 AM
This page I made might help. Look on the last pages for adjustment info.
http://www.naylor1.com/mxthunder/warcam.html
04 YFZ450 - WR Kit, CP 13:1 piston, PC Ti-4 pipe, hotcam intake, cam mod, YZ clutch mod, GYTR basket, FCI intake, jetted, scotts fuel screw, 1" lowering peg nerfs, LSR axle, 15T front sproket, Tag bars, PRM desert grab bar, AC bumper, MXR4 rears, skid plate, pro design kill, various other weight saving mods. | OhioMafiaRiders
02-10-2010, 04:46 PM
are u positive about those clearance specs i went to another site and they said intake 0.05 and exhaust 0.07
how to adjust valves on yamaha warrior 350, yamaha warrior valve adjustment, yamaha warrior 350 valve adjustment, how to adjust the valves on a yamaha warrior, warrior valve adjustment, how to adjust valves on a yamaha warrior, how do you adjust the valves on a 2001 yamaha warrior 350, 01 yamaha warrior 350 valve adjustment, valve adjustment yamaha warrior 350, valve adjustment on yamaha warrior, 2002 yamaha warrior 350 valve adjustment, how to adjust yamaha warrior valves
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Valve Adjustment
2000 YFM350X |
Yamaha YFM350 Raptor/Warrior ('87-Present) |
11 |
10-03-2011 12:35 PM |
Valve Adjustment
Archie |
Yamaha YFM700R Raptor (2006-Present) |
3 |
09-01-2005 08:02 AM |
Valve adjustment
Stubby660 |
Yamaha YFM660R Raptor (2001-2005) |
2 |
02-18-2004 11:17 AM |
Valve adjustment
Cereal Killer |
9 |
02-15-2004 02:23 PM |
Valve adjustment on a Warrior
Joey |
6 |
06-06-2002 11:06 AM |
