warrior chain adjustment help - Yamaha ATV Forum
This is a discussion on warrior chain adjustment help within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; Now I know this may sound like a really dumb question but I couldn't find the answer in any other posts. How do you properly ...
Old 08-03-2004, 12:12 AM   #1
View dirtdevil's Photo Gallery(0)
Default warrior chain adjustment help
Now I know this may sound like a really dumb question but I couldn't find the answer in any other posts. How do you properly adjust a warriors chain? If too tight it can break on landing and if it doesn't break it can pull and bust your case. I think mine is too lose because it makes a lot of noise and seems to have a lot of slack. Is there an easy rule of thumb or measurment? I have a shop manual and it says something like 1.5 inches of slack. I don't quite understand and don't want to f up. :( Can someone explain please? Thanks
TRX450R and 03 WARRIOR
"I'd rather trust a country man than a towns man." >Genesis "Lamb Lies Down on Broadway"
"Let us learn to show our friendship for a man when he is alive and not after he is dead."
>The Great Gatsby
dirtdevil is offline   Reply With Quote
Old 08-03-2004, 12:17 AM   #2
View weed smokin warrior's Photo Gallery(0)
slack i beleive is the space between the top of the swingarm, to where the chain streches up the most. if that makes any sence.
02 black warrior
white bros e2 silencer
razr rears, soon fronts also.
burgard +2 inch a arms
works performance dual rate fronts with rezzies
pro design adapter and filter
wiseco piston
coming soon, lsr axle, razr fronts, and hotcam
weed smokin warrior is offline   Reply With Quote
Old 08-03-2004, 12:22 AM   #3
tOj
View tOj's Photo Gallery(0)
loosen both swingarm carrier bolts, pull back as far as tight as u want it, adjust the two backing bolts so they are exactly even (count the threads) and then tighten the swingarm carrier bolts back in place should be good to go,, ass
Built Banshee
2001 Frame 96 Motor LSR2.1/Elka/Durablue2.2/Quicksand2.5/8 ITP Baja/Kenda Klaw
tOj is offline   Reply With Quote
Old 08-03-2004, 05:56 AM   #4
View mxthunder's Photo Gallery(0)
Lately I have been adjusting my chains simly by pulling back (with all the carrier bolts loose) until there is no slack in the chain. When the suspention goes down, it doesn't affect the tension of the chain. I havn't had a problem yet.
04 YFZ450 - WR crank, oil mod, CP 13:1 piston, Full Yosh TRS Ti pipe, hotcams intake, cam mod, YZ clutch mod, GYTR basket, FCI, 1" lowering peg nerfs, LSR axle, Pro tapers and Housier +1" stem, PRM desert grab bar, AC bumper, XCR tires and more 175M NCVQ #5 50p | 2010 YFZ450X - HMF Tuner, PRM bolt-ons, Aluminum airbox + K&N Filter
mxthunder is offline   Reply With Quote
Old 08-03-2004, 08:50 AM   #5
Warrior King's Avatar
View Warrior King's Photo Gallery(0)
yes it does, but when u pull it back all the way there is still some movement in the chain because the links can move. 1 inch of play is good, that means ur chain can m ove up and down 1 inch. (.5 each way) just have some one jump on ur grab bar and make shure ur chain dosent get to tense.
Need a dirt bike :(
Warrior King is offline   Reply With Quote
Old 08-03-2004, 09:39 AM   #6
View DuAL PiPES's Photo Gallery(0)
you know what works best? read your manual. thats why you get one with a quad.... i dont know why people go on the internet to find stuff that is thoroughly explained in thier manual
2004 KFX400
DuAL PiPES is offline   Reply With Quote
Old 08-03-2004, 09:55 AM   #7
View HubMonkey's Photo Gallery(0)
Maybe because he does not have his manual. Maybe his dog ate it. He needs help and is asking for it here.
Here is a link to the Tech tips section it has the exact operation with pics.
http://www.bluetraxx.com/chain_adjustment_new.htm
Hub
I Love Cats... I Just Can't Eat a Whole One.
http://www.roostingthedunes.com
Not Your Mother's ATV Site!
HubMonkey is offline   Reply With Quote
Old 08-03-2004, 11:04 AM   #8
View yamwarrior101's Photo Gallery(0)
its a pain in the ass
04 Red 400ex razr rears,dg alloy nerfs more to come...
yamwarrior101 is offline   Reply With Quote
Old 08-03-2004, 06:36 PM   #9
Thanks hubmonkey. Dual Pipes blow me. This is exactly what I made mention to before I asked the question, critizism. I have a Clymer manual and it says 1.18-1.57 inches of free play. It also says to support the rear off the ground so you can turn the tires. Do you support it using the swingarm or the frame because both will give you different readings because one is unloading the shock and one is not. I just know a lot can go wrong if you don't do it right. I can guess like everyone else or see if I can get a little help from BT. I have also been told to get 2 friends and sit them on the back and make sure the chain is not tight, as long as it is not than your good to go. Chump
>The Great Gatsby
Old 08-03-2004, 06:43 PM   #10
Hey, in the manual it says to take measurments from the middle of the chain on the bottom. The part of the chain that is returning to rear sprocket. In the BT "how to" it says to measure on the top part of the chain. Neither directions makes mestion of whether the suspension should be unloaded or not. What do I do now? Guess?
>The Great Gatsby
Old 09-25-2014, 07:35 PM   #11
View 1990yamawarrior350's Photo Gallery(0)
I'm new to atvs and not really that inclined on wrenching which two bolts is it that you have to loosen to tighten the chain
1990yamawarrior350 is offline   Reply With Quote
Old 09-25-2014, 08:35 PM   #12
by the way my chain is tight on the top but the bottom is loose idk if that matters or what like I said im new learning as I go
Old 09-26-2014, 11:45 PM   #13
9five9's Avatar
View 9five9's Photo Gallery(0)
I'm trying to figure out the swing arm adjustments too. But the reason the chain is tight on the top and loose on the bottom is just because of the way that it rotates. It'll always have tension on the top regardless of how tight or loose it is.
I can't keep my chain on. In the morning I'm gonna try adjusting the swing arm. I also noticed my chain guide is broken. Pretty sure it's been that way since I got the quad 3 years ago. Does anyone ride without one? should I put a new one on there?
9five9 is offline   Reply With Quote
yamaha warrior chain adjustment
warrior 350 chain adjustment
how to adjust chain on warrior 350
how to tighten a chain on a 350 warrior
how to tighten a chain on a 2002 yamaha warrior
how to tighten the chain on a 350 warrior
bolts for tightening chain 1987 yamaha warrior 350
how to know when a chain is too loose on a yamaha warrier?
1992 yamaha 350 warrior tightening chain
adjusting warrior 350 chain
how to adjust chain on yamaha warrior
how to tighten chain on 03 warrior
Chain Adjustment? Grizly3610 Yamaha YFM660R Raptor (2001-2005) 4 06-21-2005 12:47 AM
new chain adjustment help blackh8552 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 05-02-2005 09:35 PM
Chain adjustment bigmackloud Yamaha YFM350 Raptor/Warrior ('87-Present) 9 05-18-2003 03:39 PM
Chain out of adjustment already? Two4One Yamaha YFZ350 Banshee (1987-Present) 4 12-19-2002 09:12 AM
chain adjustment RaCe WaRrIoR 19 Yamaha YFM660R Raptor (2001-2005) 5 02-03-2002 02:07 PM
