06-07-2004, 11:12 AM
crankcase breather hose
does anyone make a filter for the crankcase breather hose?
2005 Yamaha Banshee
Pro Circuit full exhaust, Maxxis Razrs/Black race rims on all 4's, DG front bumper, Pro Taper handelbars
198? Honda 250R & 1986 Honda 250R - Project Quad
06-07-2004, 11:17 AM
I don't think so but I am sure you can find something at an auto parts store to work. Use your imagination.
2001 Warrior Team Blue
White Brothers E-series, DG alloy nerf bars, K&N Jet w/ K&N filter and outer wear, Oil cooler, Steel braided brake lines, WB swing arm skid, .450 cam, JE 10.75 piston, renthal bars, Ac front bumper,
"The difference between Men and Boys is the price of their Toys"
06-07-2004, 11:20 AM
I used a K&N filter that was designed for a .21 nitro engine from an R/C car. I left the hose on and mounted the filter on top. It is tucked up next to where the snorkel used to be...
You can get these lil filters, foam style even for $5-$20 on Ebay, or your local hobby store..
06-07-2004, 11:33 AM
2005 Yamaha Banshee
06-07-2004, 12:42 PM
I have a question about this yopic, Since the breather hose blows outward, why would you want to filter it?
-Kahuna
2002 Honda 400ex
Not enough to list.
06-07-2004, 01:11 PM
It doesn't always breathe out, when your bike dies(never on a warrior  ) or you shut it off it could draw in..
06-07-2004, 02:27 PM
Zip tie a peice from some pantyhose(SP) on there. That should be enough of a filter no one will see it and it will filter ok. Cheap and easy. That sounded funny me trying to be all techinical about pantyhose for an air breather.
2001 black/white/yellow warrior
Yoshimura and edelbrock carburator installed.
Too much to list!!
06-07-2004, 03:58 PM
Nitro RC car filters seem to work really well. Not only does it stop stuff from getting sucked in, but also from falling down the tube and into the case. I suppose you can do what dsw warrior350 said. it isn't as refined looking, but it is cheap and gets the job done  . For one weekend when I ran without a lid, I just used a rag rubberbanded to it :) . I don't recommend that though :)
-=Tug Hill 2004 Veteran=-
2004 YFZ450.LE
*Big Gun Racing Exhaust (Full system ceramic coated)
*SRP Metals steering dampner
*Custom Aluminum ORV Plate
*Dynojet Jetted
*Shark Teeth Graphics
*AC Racing Nerfs
06-07-2004, 04:12 PM
I think tOj has some sort of aftermarket breather on his warrior.
04 YFZ450 - WR Kit, CP 13:1 piston, PC Ti-4 pipe, hotcam intake, cam mod, YZ clutch mod, GYTR basket, FCI intake, jetted, scotts fuel screw, 1" lowering peg nerfs, LSR axle, 15T front sproket, Tag bars, PRM desert grab bar, AC bumper, MXR4 rears, skid plate, pro design kill, various other weight saving mods. | OhioMafiaRiders
06-07-2004, 10:38 PM
#10
thanks for all of the tips. i am prolly gonna go with dsw warrior350'd idea. lot cheaper than a $20 filter.
2005 Yamaha Banshee
06-08-2004, 08:37 AM
#11
I think they use a breather hose so water doesnt get in. It would with pantyhose for sure and even with a small filter, just go buy some hose somewhere and connect it to the air box.
'87 Warrior Red frame, Silver Maier fenders, Wisco piston, HMF, Uni air filter, Razr w/ITP T-9s, AC Bumper ,PRM Z-Plate skid plates, shock covers, pro grips
'03 Honda 400ex. HMF slip-on, K&N w/ pre-wrap, Dyno-jet kit, Renthal bars, DG Fat Nerfs, Power Madd, DG Full Body Skid, Factory Effex Grafix Kit, Kenda Klaws
06-08-2004, 01:08 PM
#12
also the filter will protect it from letting dirt and dust being sucked in
2001 warrior...durablue axle, nerfs, razr all around, fmf full pipe, pro flow adaptor, .430 web cam, weisco piston, ti springs, barnett clutch kit, works shocks, raptor rear, oil cooler, and 14 tooth front, wheel spacers, pep steering stabalizer, air scoops,
06-08-2004, 07:35 PM
#13
I like the filter idea the best, but I don't think panty hose idea is a bad idea. If you keep the breather hose as high as the air filter, the chance of water getting in it is minimal (and if it does, your air filter is under water regardless ;lol: ) . Small dust might find its way in, but it would be very little. Anything small enough to fit past the weave of a panty hose mateiral, is probably smaller then any clutch debris or metal shavings you may have floating around in there anyway.
I personally would feel safer about running an actual filter, but running material over it (as long as the pores are small), shouldn't be too big of a problem. Also, most dust would come by durring operation, and under operation I would think the crankcase preasure would be positive not negative, so vapor would be escaping through the hose, not the other way around.
2004 YFZ450.LE
*Dynojet Jetted
*AC Racing Nerfs
06-08-2004, 08:37 PM
#14
Heres a direct link for the one at JLatv. It looks like a good product i would go with that. http://www.jlatvproducts.com/Merchan...ct_Code=621010
Too much to list!!
06-12-2004, 08:17 AM
#15
Dennis Kirk has one that works really good the part number is 30-1590 $14 I run one on both of my warriors. and my grizzly when I have the air box lid off
06-14-2004, 06:28 AM
#16
might try this. Its a fuel filter from wally world
06-14-2004, 08:37 AM
#17
I bought a car pvc valve at autozone for 2.99
-----------FOR SALE------------
-------------$2800--------------
2001 Warrior, too much to list
06-14-2004, 02:44 PM
#18
Taco I ran one for a lil while too. There is one tiny lil problem with em though. The crank case pulls and pushes air, but isint a PCV only one way?
Y2k KX500
98 Warrior - RIP
1994 Trailboss 250- Wifes ride, a lot faster than I thought it would be!
1973 RD350
06-22-2004, 03:57 PM
#19
it appears the pvc that i have will go both ways . .hmm i must investigate further
07-12-2004, 06:28 PM
#20
ok who can tell me what the bolt sticking out of the head just above the vent hose does or is for ?
<----- kahuna not me stop calling me kahuna
www.freewebs.com/dylandot
03 Z400 #11
TC racing custom built 450 motor
yoshimura ignition
guseted frame gibson pro pegs JB racing steering stem
mxr4s mx fronts on the way
soon to get the roll design lobo II kit with triple rate dual remote and piggy back rezzys
yamaha banshee breather hose, yamaha banshee hose diagram, where does breather in crankcase for yamaha warrior 350, warrior 350 crankcase tube, banshee crankcase hoses, where does blaster crankcase hose hook up, banshee crankcase vent, what can a defective breather hose cause honda 2003, hose on yamaha blaster carburator from crankcase, banshee 350 crank hose rought, banshee water pump breather hose, warrior 350 oil vent tube
