Parking brake elimination
This is a discussion on Parking brake elimination within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; As soon as I get my bike started, I am going to get rid of the parking brake. All I have to do is remove ...
Old 12-29-2003, 08:46 PM   #1
View Sharptj's Photo Gallery(0)
Default Parking brake elimination
As soon as I get my bike started, I am going to get rid of the parking brake. All I have to do is remove the wires and then plug the two at the handlebars together and block something off at the rear caliper...right?
John
2002 Raptor 660R
HMF exhaust
K&N airfilter
Sharptj is offline   Reply With Quote
Old 12-30-2003, 03:49 PM   #2
View crotts's Photo Gallery(0)
Yes all you do is remove the brake cable and unplug the two sets of wires
Then plug these two together
Then just install a block off back at the caliper and your good to go
'99 Warrior, JE 12:1 Piston bored .080 over, Megacycle .450 lift Cam with R/D Valve Springs, P&P w/ valve job, K&N w/outerwear, EHS Racing Mod. Airbox Lid, FMF Titanium-4 Muffler w/PowerBomb Header, Oil Cooler from mascman, Wicked +2 Arms, Dual Rate Adj. Elkas w/rezzies, Galfer braided brake lines, 22" Razer2 on Douglas Red Labels all around.
crotts is offline   Reply With Quote
Old 12-31-2003, 08:38 PM   #3
montycarlo's Avatar
View montycarlo's Photo Gallery(0)
I just clipped the upper set of wires - the lower is for the clutch switch I think. I left my clutch switch intact to prevent silly accidents. Of course if you plug the brake switch wires together instead of the clutch switch you'll have a general "runs like crap" condition.
--McPartlin & Sons Racing--
Iowa ATV Harescramble Series
Dave- B class #141 08 Outlaw 450MXR
Landon 07 KFX50 50cc Stock #99
Conner- Radio Flyer (AA hopeful!)
montycarlo is offline   Reply With Quote
Old 01-01-2004, 08:07 AM   #4
View CHUBBCHUBB's Photo Gallery(0)
MontyCarlo is right. I did it the other way and had nothing but problems. When you place the plate on put some silicone or waterproof sealant on too.
2001 WARRIOR (SOLD)
2000 KTM 250EXC (STOLEN)
1997 KLX 300 (STOLEN)
CHUBBCHUBB is offline   Reply With Quote
Old 01-01-2004, 08:10 AM   #5
montycarlo's Avatar
:D or buy the Noss Machine one (off of the BT links page) that has a groove machined in it for an o-ring.
Old 05-12-2004, 09:37 PM   #6
View mxwarrioir23's Photo Gallery(0)
what wires are u plugging in to after u take all that stuff out
i broke one of them off at the brake part on the bars in a crash and it has bin runnin crappy since then now i got the block off on is that y cause i didnt plug them in to each other ?
mxwarrioir23 is offline   Reply With Quote
Old 05-12-2004, 11:24 PM   #7
montycarlo's Avatar
check that your clutch switch wires aren't the broken ones. The parking brake switch wires should NOT be shorted together. Clutch switch YES, parking brake NO. Make sure the parking brake wires aren't shorted to the bars, either.
Old 05-13-2004, 12:46 AM   #8
View Pokey's Photo Gallery(0)
The only reason to have that brake is for traveling, and you can accomplish the same thing by ziptying the brake lever on!
'02 Raptor - CT Sonic Exhaust, ProDesign w/K&N and no lid.
Red '05 Grizzly 660
Pokey is offline   Reply With Quote
Old 05-13-2004, 03:50 PM   #9
witch is witch the top or bottom
and wat if they are the ones that are broken
<----- kahuna not me stop calling me kahuna
www.freewebs.com/dylandot
03 Z400 #11
TC racing custom built 450 motor
yoshimura ignition
guseted frame gibson pro pegs JB racing steering stem
mxr4s mx fronts on the way
soon to get the roll design lobo II kit with triple rate dual remote and piggy back rezzys
Old 05-13-2004, 05:41 PM   #10
montycarlo's Avatar
If you look at it, the clutch lever and switch is mounted below the brake lever and switch.
If the brake switch wires are broken, I would say to clip them off and tape them so they don't touch anything.
Old 05-26-2004, 06:07 PM   #11
View war98rior's Photo Gallery(0)
where abouts are these wires that your supposed to plug together.....i think this is the problem with mine... how could i tell?
war98rior is offline   Reply With Quote
Old 05-26-2004, 06:43 PM   #12
View RAS928's Photo Gallery(0)
you dont have to cut those wires, you can just unplug them where they connect under the "hood"
RAS928 is offline   Reply With Quote
Old 05-26-2004, 06:57 PM   #13
View MrSlithers's Photo Gallery(0)
That will let water and dirt in there which isn't good. Same thing when removing the tail light.
To many.....
MrSlithers is offline   Reply With Quote
Old 04-14-2008, 05:43 PM   #14
View jbstacy's Photo Gallery(0)
what do i need to see the pictures on this page all i see is a red x can someone email me the pics
jbstacy is offline   Reply With Quote
Old 04-15-2008, 08:27 AM   #15
It is pretty straight forward.
THere are two sets of wires leading to the clutch lever. One will have one white connector for both wires. Simply unplug it, if you are worried about moisture put a dab of RTV on. The other set of wires will have a pair of bullet connectors, they will plug into themselves. Plug them into themselves on the quad side. You may have to follow the wires down from the clutch handle under the hood.
06' Wolverine
Old 09-13-2008, 02:37 PM   #16
warriorman2003's Avatar
View warriorman2003's Photo Gallery(0)
i just cut the wires from the parking brake, to eliminate the crappy running situation with mine.
warriorman2003 is offline   Reply With Quote
Old 04-02-2009, 08:03 PM   #17
View thejbombs's Photo Gallery(0)
can you be more specific on the "crappy running conditions", because i think i am having a situation with my parking brake and i want to compare symptoms
thejbombs is offline   Reply With Quote
Old 04-08-2009, 02:21 PM   #18
View lazerous's Photo Gallery(0)
i just got a 87 warrior it will not start the fire is verry week the fire is white looking ,ive checked the stators they look new ,there are no broken wires,ive checked the coil i took one off my moto-4 still week ,i cleaned all connections,checked all the harness from front to back ,put in new spark plug ,nothing has been cut or is grounded ,could it be the excitor box it has 2 plugs going into it dont know whats what there? dont know if the cdi unit is built in it i guess so though maby ? could someone please help ime at a loss for words,plenty of cussin but no words...
lazerous is offline   Reply With Quote
Old 04-08-2009, 04:58 PM   #19
i checked my warrior and seen where the clutch wires and brake wires went on the handlebars but its long gone not a switch or wire insight,under the nose plastic there is a white 2 wire plug with a green wire yello stripe and a black wire whats that for ?plus 2 brown wires 1 blue,1black where do they hook to.any ideas could they be my week spark problem....
Old 04-09-2009, 09:30 AM   #20
The white connector is your clutch I believe, and the other wires should plug into each other, if they are not try it.
06' Wolverine
raptor 660 parking brake removal
yamaha warrior parking brake switch elimination
yamaha warrior 350 parking brake switch
yamaha banshee parking brake removal
raptor 660 parking brake sensor
warrior 350 parking brake sensor
yamaha wolverine parking brake switch
picture of parking brake cord on handle bars of 2000 350 yamaha warrior
black and yellow wire and black wire from wire harness for 05 warrior 350
2001 warrior yamaha removing park brake
raptor 660 remove parking brake
parking brake Leavin-BHND Yamaha YFM660R Raptor (2001-2005) 18 08-13-2004 08:40 PM
Parking Brake Starscream Yamaha YFZ350 Banshee (1987-Present) 3 08-12-2003 10:10 PM
PARKING BRAKE ELIMINATION 31raptor Yamaha YFM660R Raptor (2001-2005) 22 10-27-2002 11:39 AM
Park brake elimination quisenb1 Yamaha YFZ350 Banshee (1987-Present) 5 10-25-2002 07:17 PM
RAPTOR E-BRAKE ELIMINATION 31raptor News/Support/Feedback 3 10-17-2002 02:09 PM
