Cleaning an air filter? - Yamaha ATV Forum
This is a discussion on Cleaning an air filter? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; After I have removed and washed my air filter out, what kind of oil can I use on the filter? Do I have to use ...
Old 10-06-2003, 10:50 AM   #1
View warrior_8301's Photo Gallery(0)
Default Cleaning an air filter?
After I have removed and washed my air filter out, what kind of oil can I use on the filter? Do I have to use air filter oil or can I use something else and if not do I have to do to an atv dealership to get it? Sorry if these are stupid questions but I have never done this before . Thanks
warrior_8301 is offline   Reply With Quote
Old 10-06-2003, 11:00 AM   #2
stock filter - clean with solvent, oil with engine oil, dump some on squeeze out the excess.
Uni - clean with solvent, oil with foam filer oil - PJ1 or uni, my recommendations.
K&N - Use the K&N clening and oil kit.
Old 10-06-2003, 11:26 AM   #3
View WarriorRacer#13's Photo Gallery(0)
What kind of 'solvent' are you talking about? I usually use Castrol Super Clean...real good stuff, it'll even 'clean' the skin off your fingers after a while :)
WarriorRacer#13 is offline   Reply With Quote
Old 10-06-2003, 01:18 PM   #4
View Kahuna's Photo Gallery(0)
I just use gas to clean mine. But why do you need air filter oil? I don't put any on mine and it does fine.
2002 Honda 400ex
Not enough to list.
Kahuna is offline   Reply With Quote
Old 10-06-2003, 02:31 PM   #5
Very bad, very, very bad...... Unless u are running a paper filter. Any and every foam style filter is designed to work with oil. The foam alone doesn't catch all the dirt particles, 2 months ago I rebuilt a buddies RM125, I told him to clean and oil the filter, he didn't. it lasted maybe 5 hours and the rings had a gap the size of a nickel, and were half the width they were supposed to be. The carb had a oily mud coating on the filter side. And the bike has a uni and a inner foam filter........
OIL YOUR FOAM FILTERS!!!!!!!!!!!!!!!
Old 10-06-2003, 03:06 PM   #6
And clean them with what???
Old 10-06-2003, 04:03 PM   #7
mineral solvents is the best, if you don't have access to a solvent tank, I would buy some mineral spirits, cheap by the gallon. The prob. with gas is it can soften the glues that hold some foam filters together. If you cannot get mineral spirits or solvents, I would use hot water with alot of soap... Make sure and let it dry thoroughly so the oil spreads evenly.
Old 10-06-2003, 08:07 PM   #8
View SpecWarrior's Photo Gallery(0)
If it is a foam filter, I just use dishsoap. Seems to leave some mild amounts of oil behind, but I never see any dirt in the filter after I'm done washing it.
-=Tug Hill 2004 Veteran=-
2004 YFZ450.LE
*Big Gun Racing Exhaust (Full system ceramic coated)
*SRP Metals steering dampner
*Custom Aluminum ORV Plate
*Dynojet Jetted
*Shark Teeth Graphics
*AC Racing Nerfs
SpecWarrior is offline   Reply With Quote
Old 10-06-2003, 09:05 PM   #9
montycarlo's Avatar
View montycarlo's Photo Gallery(0)
I have a UNI & cleaning with gas has not affected the glue on it - YET....
Soap and water sounds like a good idea to me I guess! :)
--McPartlin & Sons Racing--
Iowa ATV Harescramble Series
Dave- B class #141 08 Outlaw 450MXR
Landon 07 KFX50 50cc Stock #99
Conner- Radio Flyer (AA hopeful!)
montycarlo is offline   Reply With Quote
Old 10-08-2003, 02:11 PM   #10
View WarriorMaster's Photo Gallery(0)
1. Use soap and warm water, scrub the dirt out.
2. Let it dry
3. Use foam cleaner in a spyay bottle (smells like carb cleaner)
4. Let it dry again
5. Soak it in 10w30 oil...
6. Squeeze off most oil excess.
7. Reinstall
2001 Blue Yamaha Warrior - Baja swing arm skid plate - Baja Full Chassis skid plate -22x11x9 6-ply Maxxis Razr's Rear Tires - White Bro's E-Series with 9 Disc's - James Lucky Parking Break Kit - Pro Flow
WarriorMaster is offline   Reply With Quote
Old 10-08-2003, 06:11 PM   #11
I recommend using foam filter oil (especially if it is an aftermarket like UNI). Regular motor oil works, but tends to run out of the filter and into the box. Foam oil is extremely tacky and not only stays in the filter, but also grabs dirt particles better.
2004 YFZ450.LE
*Dynojet Jetted
*AC Racing Nerfs
how to clean raptor 660 air filter
how to change air filter on yamaha rhino
how to clean k and n air filter in yamaha raptor
how do i change air filters in a 2005 660 yamaha rhino
yamaha rhino air filter cleaning
what oil for raptor 350 foam air filter
should you put oil on the air filter of a raptor 660
how to get the air filter off a 660 raptor
diy clean air filter yamaha warrior 350
cleaning yamaha rhino air filter
what type of oil do i use on my yamaha rhino air filter
cleaning air filter for 350 yahama raptor
cleaning your air filter tazlittleking Yamaha YFM660R Raptor (2001-2005) 12 01-28-2005 05:57 PM
Cleaning K&N filter PAVERY1500 Yamaha YFM660R Raptor (2001-2005) 4 05-23-2003 08:26 AM
air filter cleaning? yamaha4eva Yamaha YFM660R Raptor (2001-2005) 6 09-17-2002 08:27 PM
