white smoke just before idle?? - Yamaha ATV Forum
This is a discussion on white smoke just before idle?? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; Hey, today i replaced my header gasket. not sure if the old one was bad or not, but it sure did look pretty bad. but ...
Old 08-29-2003, 07:02 PM   #1
View bigmackloud's Photo Gallery(0)
Default white smoke just before idle??
Hey,
today i replaced my header gasket. not sure if the old one was bad or not, but it sure did look pretty bad. but i can't say that it runs any differently.
ne ways, i noticed that if i rev the engine and then let it fall back to idle, it'll blow some white smoke just before i goes back to idle. now my smoke reading skills are a little rusty but blue smoke = oil, black smoke = too rich, and white smoke = lean???
i'm also going to adjust my valves soon, so hopefully that'll show an improvement in how it runs as well.
side question: when checking the valves the motor has to be at TDC. how do you turn the motor to get it to TDC?
thanks,
bigmac
'97 Warrior - DG exhaust, K&N filter and modified airbox, jetted, 20" Shredders - Sold 10-20-03
bigmackloud is offline   Reply With Quote
Old 08-29-2003, 07:44 PM   #2
View SpecWarrior's Photo Gallery(0)
Not sure bigmac. I know mine will smoke a tad whitish looking when it is first started but then goes away soon after. I do know mine blows black smoke if I really lay into the throttle, but I know mine is running a tad rich anyway.
Does yours do it when it is cold, or after it has warmed up?
-=Tug Hill 2004 Veteran=-
2004 YFZ450.LE
*Big Gun Racing Exhaust (Full system ceramic coated)
*SRP Metals steering dampner
*Custom Aluminum ORV Plate
*Dynojet Jetted
*Shark Teeth Graphics
*AC Racing Nerfs
SpecWarrior is offline   Reply With Quote
Old 08-29-2003, 08:06 PM   #3
Hey,
this is after it's warmed up.
cheers,
bigmac
Old 08-29-2003, 10:42 PM   #4
montycarlo's Avatar
View montycarlo's Photo Gallery(0)
blue black white yellow green orange maroon gold I wish my dang Warrior blew some dang smoke of some dang color.
--McPartlin & Sons Racing--
Iowa ATV Harescramble Series
Dave- B class #141 08 Outlaw 450MXR
Landon 07 KFX50 50cc Stock #99
Conner- Radio Flyer (AA hopeful!)
montycarlo is offline   Reply With Quote
Old 08-30-2003, 01:48 AM   #5
View dsw warrior350's Photo Gallery(0)
my dg exhaust does it too and i dont know why, i thought maybe it was some packing, but mines blue colored, when should you adjust your valves
2001 black/white/yellow warrior
Yoshimura and edelbrock carburator installed.
Too much to list!!
dsw warrior350 is offline   Reply With Quote
Old 08-30-2003, 05:12 PM   #6
View RAS928's Photo Gallery(0)
you? right now
RAS928 is offline   Reply With Quote
Old 08-30-2003, 06:19 PM   #7
View jakalwarrior's Photo Gallery(0)
If its lean coming back down from being revved check the coasting enricher is probably messed up. Thats the little thingy under the plastic white cover on the side.. If there are holes in the rubber diaphram it wont work and wont choke the engine on rev down.
2 wheels: Y2k KX500 - 2002 YZ125 - 2012 ZX6R - 2002 VTX1800C - 1973 RD350
4 wheels: 2007 Raptor 700, 1994 Trailboss 250
jakalwarrior is offline   Reply With Quote
Old 08-30-2003, 07:58 PM   #8
Warrior King's Avatar
View Warrior King's Photo Gallery(0)
what about valve seals?
Need a dirt bike :(
Warrior King is offline   Reply With Quote
Old 08-30-2003, 08:04 PM   #9
They make a black puff of smoke when your first start it up. My friends 400ex just had to get new ones. He got tired of the embarassing smoke on startup, guess it had to do with my calling it a POS smoking honda
Old 08-30-2003, 08:58 PM   #10
View WarriorRacer#13's Photo Gallery(0)
WELLLLLLL...since nobody's gfonna answer your question about TDC here you go. 1. Take the little plastic side cover off the flywheel side of the bottom end. You'll see the head of a bolt sticking out. A 17mm socket will fit it. 2. Take the little black plug out of the top of the flywheel cover (it's about an inch wide) You may have to use a flashlight to see down in the hole, but...turn the flywheel with the ratchet SLOWLY and you will see the timing mark go by. It's a capital letter T and has a line under it. On the edge of the hole you took the plug out of will bea line. Line up the two lines and BOOM Top Dead Center. Just make sure it stays there as you adjust the valves. And by the way, if you figure out what tool to use to turn the tappets themselves (other than a pair of pliers) let me know. I don;t think they make a wrench that small :)
WarriorRacer#13 is offline   Reply With Quote
yamaha warrior white smoke
2003 yamaha warrior blows black smoke when running
rd 350 white smoke header
rd350 white smoke
400ex blowing white smoke
yamaha raptor 250 2008 white smoke at start up
kx500 smokeing white smoke
yamaha warrior smokes 400ex
yamaha 350 warrior blows out white smoke when full throttle
rz 350 blowing white smoke
95 yamaha worrior smokes white
polaris rager500 white smoke
exhaust, white smoke, and oil!!! dirtbikr86 Yamaha YFZ350 Banshee (1987-Present) 9 03-23-2011 09:02 PM
white smoke Kawasaki650 Other Models/Brands 13 08-05-2004 01:16 AM
White smoke when accelerating????? raptorff Yamaha YFM660R Raptor (2001-2005) 21 07-05-2004 07:18 PM
lil bit of white smoke?? 4shtyReater Yamaha YFM660R Raptor (2001-2005) 6 05-24-2004 08:39 PM
White smoke 204fmf Yamaha YFS200 Blaster ('88-Present) 10 03-02-2003 10:54 AM
