Clutch Adjustment? - Yamaha ATV Forum
Clutch Adjustment?
This is a discussion on Clutch Adjustment? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I put in a new EBC clutch, and (it didnt before) but the clutch cable does not have enough slack to let the lever go ...
Old 01-03-2003, 11:18 PM   #1
View jakalwarrior's Photo Gallery(0)
Default Clutch Adjustment?
I put in a new EBC clutch, and (it didnt before) but the clutch cable does not have enough slack to let the lever go back to the disengage marks. I did accidentally take the lil gear thingy out when I had the cover off but I set it back to where it fell between the marks when it disengaged. I loosened the one on the handle, and the one at the base... Think I should buy a new cable or would it be the same length?. Ive never heard of a cable shrinking but I also dont know what the previous owner did to it.
On a side note this aftermarket sucker is SOOOO hard to pull. I used to just use two fingers when shifting at the action was real light. Now I have to use 4 fingers and almost strain. I dont think I would be able to do mroe than about 4 or 5 drag races and my fingers would be wore out. Its not me though, im no where near being a lil guy.
2 wheels: Y2k KX500 - 2002 YZ125 - 2012 ZX6R - 2002 VTX1800C - 1973 RD350
4 wheels: 2007 Raptor 700, 1994 Trailboss 250
jakalwarrior is offline   Reply With Quote
Old 01-03-2003, 11:20 PM   #2
View warrior-man's Photo Gallery(0)
Sounds like u tightned it up too much up at the perch thing. I would check up there and try and lossen that up. But other than that
2001 Raptor- 686, Pro Circuit pipe, L&A One way, nerfs, kendas, Alba flame graphics with powdercoat job to match, everything metal powdercoated
"Thats like stuffin D cup titties in an A cup bra, just let them puppies go" - Nolan
warrior-man is offline   Reply With Quote
Old 01-03-2003, 11:37 PM   #3
got it all set as loose as it can go at both adjusters
Old 01-04-2003, 12:01 AM   #4
montycarlo's Avatar
View montycarlo's Photo Gallery(0)
If you unhook the cable at both ends it moves freely inside the sheathing, right? It isn't pinched or anything??
montycarlo is offline   Reply With Quote
Old 01-04-2003, 12:06 AM   #5
It moves pretty freely, havent had it unhooked though. You know that lil boot on the end where it hooks to the engine? The cable dosent want to come out much past that, less than 1/4" past that is all you can stretch it at the max.
rz350 clutch adjustment
rd350 clutch adjustment
how to adjust the clutch on a 05 raptor 350
rz350 clutch adjutment
adjusting the clutch on 1987 yamaha warrior 350
yamaha warrior clutch adjust
how to adjust clutch on rd 350
how to adjust clutch on r d 350
98 warrior clutch adjustment
clutch adjustment 2000 yamaha warrior 350
how to hook up clutch cable yamaha rd350
clutch adjustment 98 warrior
Help! Clutch adjustment HELP! lilsherm89 Yamaha YFZ350 Banshee (1987-Present) 5 08-11-2004 08:32 PM
Clutch Adjustment? Rappy77 Yamaha YFM660R Raptor (2001-2005) 9 04-21-2004 02:03 AM
clutch adjustment 03 raptor Yamaha YFM660R Raptor (2001-2005) 4 01-16-2004 05:38 PM
Clutch Adjustment? TrailBreaker70 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 12-23-2003 08:11 PM
clutch adjustment wade the k Yamaha YFM660R Raptor (2001-2005) 6 02-14-2002 11:23 AM
