Warrior overheating
This is a discussion on Warrior overheating within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I went riding finally the other day where my dad grew up at in farm country. Despite the mild temperatures he noticed his warrior was ...
Old 12-31-2002, 06:40 PM   #1
View MasterBlaster03's Photo Gallery(0)
Default Warrior overheating
I went riding finally the other day where my dad grew up at in farm country. Despite the mild temperatures he noticed his warrior was running and smelled like it was running hot. We continued to ride but I read on an earlier post about this problem and some ways to help cure it. I couldn't find it using search so could you all give me some suggestions.
2000 Banshee- CPI Inframes, Proflow wih K&N Filter, ITP rims, boost bottle, boyseen reeds.
MasterBlaster03 is offline   Reply With Quote
Old 12-31-2002, 06:43 PM   #2
View R4RACE's Photo Gallery(0)
did he change the jetting with that pipe?...if not start there
---Michriders---
NitrousGuy says: " i am easily twice the size as R4Race, but he rides his rappy so smoothly. when i ride mine, it feels like i am really working the quad physcially, but he looks like he rides it effortlessly. you look at him, and he is a skiny guy on this big raptor, but he is so smooth that you have to do a double take. he is not slow by any means. just smooth. "
R4RACE is offline   Reply With Quote
Old 12-31-2002, 06:44 PM   #3
Yeah when he got it the guy jetted it and everything.
Old 12-31-2002, 08:01 PM   #4
View Warrior548's Photo Gallery(0)
Check the plug color. A temperature change could have effected the jetting. If it has a white tip then go up in jet sizes until it becomes a light to chocolate brown. If the plug is all ready that color then you should get an oil cooler.
2006 YFZ450
Stock but lots to come in time
Warrior548 is offline   Reply With Quote
Old 12-31-2002, 08:21 PM   #5
View jakalwarrior's Photo Gallery(0)
If its not the jetting talk to mascman.
Y2k KX500
98 Warrior - RIP
1994 Trailboss 250- Wifes ride, a lot faster than I thought it would be!
1973 RD350
jakalwarrior is offline   Reply With Quote
Old 12-31-2002, 10:04 PM   #6
View SpecWarrior's Photo Gallery(0)
I have ridden in some hot weather in trails....lots of up and down shifting.....even for quite a while. I never noticed any heat issues. Are you sure it was overheating? Were you loosing any performance or throttle response? How do you know it overheating? An air cooled engine is meant to radiate heat...I'm sure those fins remove alot of heat from the engine and that probably makes it feel like the engine is running hot.
Also...did you just get that pipe....anything you smell could be machine oil burning off a new pipe.
I guess all I'm saying is.....I would make sure it is really overheating before I jump to conclusions. It seems like your dad isn't affraid to spend money on it with the list of mods he has on it already. An oil cooler is never a bad mod anyway, but if it is truly overheating....it's not supposed to, and an oilcooler may be trying to fix the symptom but not the cause. I'd try to figure out why it is overheating.
-=Tug Hill 2004 Veteran=-
2004 YFZ450.LE
*Big Gun Racing Exhaust (Full system ceramic coated)
*SRP Metals steering dampner
*Custom Aluminum ORV Plate
*Dynojet Jetted
*Shark Teeth Graphics
*AC Racing Nerfs
SpecWarrior is offline   Reply With Quote
Old 01-01-2003, 01:01 AM   #7
All that stuff except the tires came on the machine when we bought it off ebay for like 3100 bucks. We said it was overheating because we felt that there was a large amount of heat then usual coming off the engine. We were drag racing each other a lot o there was a lot of up and down shifting. I'll try to check the plugs tommorrow after we work on the lawnmower, but I doubt that is the problem related to jetting. What is the deal on an oil cooler where can I find one how does it work could you give me the info.
Old 01-01-2003, 09:06 AM   #8
You can get on at Four Stroke Tech. for 95 or 100 bucks. I have one but haven't put it on yet.
2006 YFZ450
Old 01-01-2003, 09:22 AM   #9
View mascman's Photo Gallery(0)
My brother has a DG on his 400ex. We repacked the silencer and it still smells after a couple rides.
For an oil cooler, check this out.
Remember though that an oil cooler is not a cure for an overheating engine. If it really is overheating I would check out the jetting like stated before. Do the plug check.
2004 Honda TRX450R
23" front & 22" rear Holeshots
Vortex Twist throttle with custom Terrycable cable
It's gone now.
2003 Warrior XC Machine
mascman is offline   Reply With Quote
Old 03-10-2003, 09:03 PM   #10
View ggilkison's Photo Gallery(0)
you can get an after market radiator for 50-60 bucks on ebay, great idea
ggilkison is offline   Reply With Quote
Old 03-10-2003, 09:20 PM   #11
View Quad82's Photo Gallery(0)
Did it feel hot or did it smell hot? If you just added a new pipe, look for a tight fit where the headder pipe and exhaust pipe meet above the clutch housing. Leaking burnt oil/smoke smell like a hot motor. Drag racing adds a lot of heat from the clutch packs too and they tend to smell like a hot motor.
87,88,91,97Warrior
04KFX
03 S-10 Crewcab
Quad82 is offline   Reply With Quote
Old 03-11-2003, 08:25 AM   #12
Humm...I wonder who ggilkison is talking about?
By the way, BT members only $60.
2004 Honda TRX450R
It's gone now.
Old 03-11-2003, 09:56 PM   #13
View youngkx41's Photo Gallery(0)
forget the lawn mower. unless your out west who cuts grass in march anyway. lmao
youngkx41 is offline   Reply With Quote
Old 03-14-2003, 11:25 PM   #14
View LMTRacerTT's Photo Gallery(0)
I sell a kit for $75 with all mounting hardware, and instructions if your interested. $40 more for steel braided lines(comes with rubber hoses)
LMTRacerTT is offline   Reply With Quote
Old 06-09-2009, 10:54 AM   #15
View warrior350rider's Photo Gallery(0)
sell a kit for what
warrior350rider is offline   Reply With Quote
Old 08-13-2009, 06:50 PM   #16
beastlywarrior's Avatar
View beastlywarrior's Photo Gallery(0)
unhappy overheating warrior
ok im new to this forum but i let my warrior idol for 20 seconds and the eghaust was making a wet paper towel steam the temputure was 75-80 and it was sitting in a garage really need help had same jey kit and pipe.
beastlywarrior is offline   Reply With Quote
Old 08-14-2009, 08:01 AM   #17
Mike Mindt's Avatar
View Mike Mindt's Photo Gallery(0)
Were do you live? If it sat in a cool moist shed, for instance, it was just the condensation steaming off.
2009 sponsors:Mike's Cabinet Tree,612-390-4313 Pat's Small Engine Plus,www.psep.biz Stenstrom Collision,320-679-4447
Mike Mindt is offline   Reply With Quote
Old 08-14-2009, 01:44 PM   #18
Rev06's Avatar
View Rev06's Photo Gallery(0)
an oil cooler is just a radiator for your oil
and check your oil...is it as full as it should be? does it need changed?
06 yfz450
waiting to start my new race build...scratch that...bought a 09 YFZ R
Rev06 is offline   Reply With Quote
Old 08-15-2009, 09:24 AM   #19
Were do you live? If it sat in a cool moist shed, for instance, it was just the condensation steaming off.[/quote]
well i live in indiana up north but it only sat for a couple of days when i had to weld the frame but... i got so hot and i didnt want to mess it up
Old 08-15-2009, 04:30 PM   #20
well im going to give it a try today and see what happends is there any thing to watch out for like melting or fire wise the tank was geting warm...
yamaha warrior overheating
warrior 350 overheating
yamaha warrior 350 overheating
yamaha wolverine overheating
normal operating temp for yamaha warrior atv
running temp for a yamaha warroir atv
warrior yfm 350 running temperature
yamaha warrior 350 over heating
yamaha yfm350 heating
new exhaust on 400ex smell like pipe melting
warrior 350 operating temp
how to tell if warrior is overheating traildogg Yamaha YFM350 Raptor/Warrior ('87-Present) 4 12-04-2012 10:59 AM
overheating CRAPTOR Yamaha YFM660R Raptor (2001-2005) 2 03-22-2005 12:31 AM
690 overheating raptorjoe660 Yamaha YFM660R Raptor (2001-2005) 21 11-17-2003 08:38 PM
overheating michael conley Other Models/Brands 15 11-27-2002 04:58 AM
