starting questions- 2003 yamaha wolverine 350 4x4 - Yamaha ATV Forum
This is a discussion on starting questions- 2003 yamaha wolverine 350 4x4 within the Yamaha Wolverine 350 / 450 forums, part of the Performance /Technical category; hi guys i bought a 2003 wolverine a few weeks ago. i love it. was working fine till i went out the other day in ...
Go Back   Yamaha ATV Forum > Performance /Technical > Yamaha Wolverine 350 / 450
Old 11-03-2012, 10:48 PM   #1
View msv268's Photo Gallery(0)
Default starting questions- 2003 yamaha wolverine 350 4x4
hi guys i bought a 2003 wolverine a few weeks ago. i love it. was working fine till i went out the other day in alot of puddles. the electric start button wont work anymore. the gree nuteral light wont light up. if i use the pull start that works fine, once it starts by using pull start the nuteral light lights up.. what shall i check first i wanna be able to use the button. thank you all for your help i appericate it very much
matthew
msv268 is offline   Reply With Quote
Old 11-04-2012, 06:48 PM   #2
a bunch of readers and no helpers?
Old 01-27-2016, 09:18 AM   #3
Bojacx's Avatar
View Bojacx's Photo Gallery(16)
Default push button start issue
I was wondering if you ever solved your problem. My 2005 Wolverine has a similar issue. most of the time when I push the start button the neutral light goes out and nothing happens. Other times it starts right up. Pull start always works. Seems like a electrical issue, any insight would help.
Bojacx is offline   Reply With Quote
Old 01-27-2016, 11:56 AM   #4
View cory52000's Photo Gallery(0)
the other guy was probably the fuse. I suspect the connections on your starter solenoid are dirty, there should be 2 small wires and 2 big wires make sure they are clean. also load test your battery it could be taking a surface charge and not have enough cranking amps to turn the engine over. is the problem more profound when it is cold. check your battery connections and the connection to the starter while you are at it.
cory52000 is online now   Reply With Quote
wolverine pull start
yamaha wolverine clicks when trying to start
yamaha wolverine 350 solution for hard starting
wolverine 350 really hard shifting
2003 yamaha wolverine clicks when trying to start
2003 yamaha wolverine 350 will not start
2003 yamaha wolverine 4x4 not starting
wolverine 350 starts hard
yamaha wolverine pull starter very hard to pull
yamaha wolverine too hard to pull start
yamaha wolverine 350 pull start hard
New to forum/98 Wolverine 350 starting problem Fred1 Yamaha Wolverine 350 / 450 6 03-27-2014 10:31 AM
2003 Raptor Starting Problem JonathanDavos Yamaha YFM660R Raptor (2001-2005) 4 12-23-2006 06:46 PM
Just got a Wolverine, have a few questions. edge Other Models/Brands 4 08-02-2004 10:24 PM
Wolverine Starting problem...check it out screamin96 Other Models/Brands 7 07-28-2003 10:28 PM
wolverine questions tony montana Other Models/Brands 5 01-08-2002 12:51 AM
