stator - Yamaha ATV Forum
stator
This is a discussion on stator within the Yamaha Wolverine 350 / 450 forums, part of the Performance /Technical category; can someone walk me through testing stator getting different stories on which wires to test the readings i should be getting and even the setting ...
Go Back   Yamaha ATV Forum > Performance /Technical > Yamaha Wolverine 350 / 450
Old 05-10-2010, 08:41 PM   #1
View keithbinwv's Photo Gallery(0)
Default stator
can someone walk me through testing stator getting different stories on which wires to test the readings i should be getting and even the setting i should have my multi tester on
keithbinwv is offline   Reply With Quote
Old 05-12-2010, 05:45 PM   #2
Default stator update
found info in manual how to test white wires from stator to regulator they checked within the 0.70-0.86 ohm range my range was 0.80-0.86 ohms but im not getting any readings on other wires going to cdi unit tried testing white/brown and white/green and red to white with no reading
i am also going to look into valves, and brake sensor (anybody know anything about this heard the two plugs on handlebar next to parkbrake) and going to test coil its a new coil but can be bad the old one checked way off the range figured it was bad will keep updated
Old 05-13-2010, 08:01 PM   #3
just checked coil both checked fine the old one that i was told by local dealer was bad even turned out to be good so now going to test CDI unit
found out today when you take your atv to a dealer with a probable stator problem and the atv is still running instead of checking stator like their supposed to they will put a meter on the battery but will charge you for testing stator
anyway going to test CDI unit if that turns out good start looking towards valves, timing, regulator, maybe other stuff
yamaha wolverine stator
yamaha wolverine stator test
how to test stator on 2000 wolverine
how to check stator on yamaha woverine
1997 yamaha 350 wolverine how to test the stator
2000 wolverine 350 stator test
how to replace stator on yamaha wolverine
checking stator on wolverine 350
2000 yamaha wolverine stator ohms
will a yamaha rhino backfire even with a bad cdi or coil
30 yamaha wolverine stator specs
stator ohms 2005 wolverine
were to get a stator jbstacy Yamaha YFM350 Raptor/Warrior ('87-Present) 5 09-02-2008 08:34 AM
200watt stator question,is resistance less on a stock stator rob the painter Yamaha YFZ350 Banshee (1987-Present) 5 04-13-2007 09:28 PM
stator martin Yamaha YFM660R Raptor (2001-2005) 5 02-13-2004 03:30 PM
bad stator thumpinhard25 Yamaha YFZ350 Banshee (1987-Present) 2 11-12-2002 06:46 PM
Stator Help rzbanshee Yamaha YFZ350 Banshee (1987-Present) 1 11-06-2001 09:38 PM
