cap cap hose - Yamaha ATV Forum
post #1 of 9 Old 09-02-2012, 07:32 PM Thread Starter
Gas cap hose
Hey Guys,
Yet another question concerning the YFM200. I finally got mine running really good, however, It gave me fits a first and it turns out the tube from the gas cap when connected prevents the engine from running properly, if I disconnect it, the engine then starts running. I have searched the web, and it seems this tube is to allow the gas to run freely, but I have not found out why it connects to the carb, most have a tube on the gas tank that dangles.
can someone let me know what this tube does exactly and why I have to leave it "open" (not connected to the gas cap ) in order to have my atv run?
Is there another issue that I need to address?
Thanks,
croc4
croc4 is offline
post #2 of 9 Old 09-03-2012, 09:25 AM
it is a air vent
fishingstar is offline
post #3 of 9 Old 09-03-2012, 11:41 AM
to give a more complete answer, the hose off the fuel cap air vents the tank so as the fuel level drops, a vacuum isnt created preventing fuel from flowing to the carb, so it sounds like somewhere the vent hose is plugged.
not being familiar with your model i'm not sure why the vent hose would run to the carb unless its an EPA thing allowing the tank to vent through a controlled atmosphere vs out into open air.
Charlie_S is offline
post #4 of 9 Old 09-03-2012, 02:27 PM Thread Starter
Thanks for the replies,
I checked the hose its clear (can blow air through it) and if I plug the end with my finger the engine dies, so it needs to be 'open', but since it was supposed to connect to the gas tank, that seems to make it into a closed type system.
So I don't understand what is going on, I have done a number of web searches to get a better idea of what is going on, but I have not found anything useful that explains it.
Croc4
croc4 is offline
post #5 of 9 Old 09-03-2012, 04:05 PM
have you checked to see if you can blow air through the tube when it's connected to the carb? I might be way off base here but i suspect as i mentioned in the previous post, its an EPA thing and by venting the tank at the carb it can draw air through the carb and thus air box for a closed system, so it would have to be a clear vent into the carb venturi at all times. On the other hand if it runs ok and the plug reads as a normal burn color, maybe plug off the carb fitting and allow the vent to freeair like the older quads do.
A quick phone call to a dealer might well clear up the issue also.
post #6 of 9 Old 09-03-2012, 05:58 PM
carsonmx114's Avatar
Both the fuel cap and the carb have their own vent hoses. Someone has replaced yours with one long hose and connected them together. Each should be a foot or so long and not connected to anything on the other end.
carsonmx114 is offline
post #7 of 9 Old 09-03-2012, 07:21 PM Thread Starter
Thanks carson, that makes sense, it must have been swapped quite some time ago because it looks 'correct', it just doesn't run connected that way
croc4
croc4 is offline
post #8 of 9 Old 09-04-2012, 06:46 PM
Glad to help. I wonder if someone relocated your final drive vent hose to the carb and fuel cap? That would explain it appearing factory. Although I can't remember if the 200 was shaft or chain drive... Just a thought.
post #9 of 9 Old 09-05-2012, 02:06 AM Thread Starter
its a shaft drive, at least the one I have is
croc4
croc4 is offline
no lid what to do with the hose off of it Melon Yamaha YFM660R Raptor (2001-2005) 5 12-31-2007 06:21 PM
engine noise / crank case hose / carb hose raptorman686 Yamaha YFM660R Raptor (2001-2005) 3 06-15-2005 08:40 PM
hose question JiM417 Yamaha YFM350 Raptor/Warrior ('87-Present) 2 06-28-2004 07:30 PM
Wow dealer tried to hose me 204fmf Yamaha YFS200 Blaster ('88-Present) 16 04-10-2004 11:47 PM
Ventalation hose...wtf Traxxastampede Yamaha YFZ350 Banshee (1987-Present) 10 11-18-2001 04:45 PM
