2006 BIG BEAR WONT GO OVER 25 MPH - Yamaha ATV Forum
post #1 of 10 Old 02-08-2012, 10:19 AM Thread Starter
CHANGED CLUTCH STILL SAME PROBLEM
ccdwiser is offline
post #2 of 10 Old 02-08-2012, 10:20 AM Thread Starter
IT IS A 400 4X4. PLEASE HELP HAVE HAD ISSUES FOR LONG TIME.
ccdwiser is offline
post #3 of 10 Old 02-08-2012, 10:34 AM
BlueBloodInTheVeins's Avatar
Did you check the Throtle stop screw on the throtle? (controls the RPM)......How long has it been like that?, did you buy it new or used?.........is it Smokeing?,what you Compression like High or Low?, did you Clean the carb?.......Got to know the symptom's and what you tried to do to fix it to help!
The Clutch was a go idea........it may be in the ajustment?
"If your thinking on takeing that hill i beat ya!"..........
BlueBloodInTheVeins is offline
post #4 of 10 Old 02-08-2012, 10:43 AM Thread Starter
COMPRESSION IS GOOD NOT SMOKING THROTTLE STOP SCREW ALL THE WAY OUT YES BOUGHT NEW IT HAS BEEN LIKE THAT FOR ABOUT A YEAR. BEEN FIGHT PROBLEM A LONG TIME. HOW DO I KNOW IF CLUTCH ADJUSTMENT IS SET RIGHT
ccdwiser is offline
post #5 of 10 Old 02-08-2012, 06:46 PM
carsonmx114's Avatar
cc, is the engine reving and the machine not matching engine speed or the engine lacking power to move the machine? Is this a manual trans unit with a footshift or an auto unit with a belt?
carsonmx114 is offline
post #6 of 10 Old 02-09-2012, 07:19 AM Thread Starter
It seems to be turning rpms when it get up there its like it rapt out at 25
Yes its a foot shorter
ccdwiser is offline
post #7 of 10 Old 02-09-2012, 08:20 AM
There are 2 clutches on a foot shifter, the primary and the main. The primary allows you to idle in gear it is a centrifugal clutch. The main clutch is just like any other atv it is a clutch pack..
Which one did you replace?
post #8 of 10 Old 02-09-2012, 08:41 AM
Good question, and did you adjust the shifter clutch? When did this problem start? What does your oil smell/look like? How many gears do you have when you shift through them? You should have 5. There's a external adjuster nut/stud for the shifter clutch, you should have at least 1/2 turn of freeplay on the stud before it seats on the clutch linkage.
post #9 of 10 Old 02-09-2012, 12:10 PM Thread Starter
I REPLACED THE MAIN CLUTCH
ccdwiser is offline
post #10 of 10 Old 02-09-2012, 12:11 PM Thread Starter
YES IT'S GOES THROUGH ALL 5 GEARS.
ccdwiser is offline
1990 big bear 350 wont start red Other Models/Brands 6 06-05-2011 10:55 AM
2006 YFZ f/s bradley3000 ATVs for Sale 1 09-02-2007 10:50 AM
2006 Yfz Quadracer89 Yamaha YFZ450/450R (2004-Present) 69 07-11-2005 02:53 AM
Big Bear wont start AFR383 Other Models/Brands 7 02-14-2005 08:08 AM
