carburetor troubles on Big Bear 400 - Yamaha ATV Forum
This is a discussion on carburetor troubles on Big Bear 400 within the Other Models/Brands forums, part of the Performance /Technical category; I had to replace the float bowl needle on my carb this weekend because it was causing gas to leak out of the side. Well ...
Old 07-17-2011, 12:24 PM   #1
View jgspahn's Photo Gallery(0)
Default carburetor troubles on Big Bear 400
I had to replace the float bowl needle on my carb this weekend because it was causing gas to leak out of the side. Well the place didnt sell just the part, but they sold an entire rebuild kit. So I decided to replace the parts etc etc. Anyways it doesnt leak gas anymore, but now when I try to run the bike, it will not run unless I cover up the snorkel with my hand. When I restrict the flow, almost all the way, It revs fine all the way, but as soon as I take my hand away it dies. I have taken all the new parts out and put the old parts back in except for the needle that originally needed to be replaced. Can someone please help me figure out what to do to get my bike to run again.. Thanks
jgspahn is offline   Reply With Quote
Old 07-17-2011, 12:25 PM   #2
By the way the bike is an 07 Big Bear 400 4x4 IRS
Old 09-17-2011, 03:54 PM   #3
View Workaholic's Photo Gallery(0)
Did you use the kits new mixture screw and set it back right? It sounds like the mixture screw or the jets were mixed around.
Workaholic is offline   Reply With Quote
Old 09-17-2011, 03:58 PM   #4
Maybe you can help me with something. I bought a rebuild kit for an 06 big bear and the main nozzle fell out of the carb upon disassembly and I don't know which side the angled part of it, up or down. If you have a manual or know it would be greatly appreciated.
big bear 400 carburetor adjustments
yamaha big bear 400 carb adjustment
2004 yamaha big bear 400 carb replace
2007 yamaha 400 big bear carb adjustments
yamaha big bear 400 carburetor adjustment
yamaha big bear 400 carburetor leaking
yamaha big bear 400 carburetor problems
2001 big bear 400 carb setting
carburetor rebuild kit for a 2001yamaha big bear
2009 yamaha 400 big bear carb air/fuel adjustment
carb adjustment on yamaha big bear
inside carburetor Manny350 Yamaha YFZ450/450R (2004-Present) 1 07-21-2005 05:18 PM
Carburetor Bore? roostinyfz Yamaha YFZ450/450R (2004-Present) 6 02-20-2004 11:05 PM
I want more carburetor..... montycarlo Yamaha YFM350 Raptor/Warrior ('87-Present) 25 12-29-2003 01:19 AM
Prices of 450 carburetor daddogrider Yamaha YFZ450/450R (2004-Present) 5 10-29-2003 10:05 PM
Carburetor runs away greendo Yamaha YFZ350 Banshee (1987-Present) 8 03-21-2002 06:44 PM
