MOTO 4 no spark - Yamaha ATV Forum
MOTO 4 no spark
This is a discussion on MOTO 4 no spark within the Other Models/Brands forums, part of the Performance /Technical category; OK I am new here, I traded a Jon Boat for a Moto 4 350 and it is not getting spark. It cranks and is ...
Old 03-25-2011, 10:18 AM   #1
View BCBow1971's Photo Gallery(0)
Default MOTO 4 no spark
OK I am new here, I traded a Jon Boat for a Moto 4 350 and it is not getting spark. It cranks and is getting fuel. I pulled the plug and cranked it over and no spark. Dealer says he has never seen a bad coild and guided me towards the Magneto. I am familiar with Small engines but haven't messed with a ATV motor is years. Well I pulled the cover off the magneto and some oil came out, not sure if that is normal or I have a bad seal, and I downloaded a manual and need to test the magneto. I guess I should just go ahead and take the rear plastic off to access everything easier.
Is there any common issues with these and starting issues. Also the headlights don't work so I am assuming that may be bad bulbs but not sure if there is a fuse that may be causing the starting issues!!
Any help is greatly appreciated!!
BCBow1971 is offline   Reply With Quote
Old 04-11-2011, 07:08 PM   #2
View hbutko's Photo Gallery(0)
Start with checking all your wire terminals including the ground and fuse. The coils do go bad occasionally, you could test it or replace it. I would rule everything elso out first before you tackle the magneto. Oil pouring out of there is normal. You dont have to replace the whole magneto, typically the pickup coil is shot, you can solder a new one into the magneto.
What year is your Moto 4 350?
I have a 87
hbutko is offline   Reply With Quote
Old 04-12-2011, 08:00 AM   #3
I have a 87
Mine is an 87 also. I am going to take it to my friends tonight and we are going to retest everything because the CDI didnt fix it. I am not sure if the Nuetral switch may be bad also....not sure but have the manual and will also try bypassing all switches and see if that makes it run. I found a Pickup for around $30-$40 and regular coil for $30.........Can't be much there is not much too these ignition systems......but its kicking my tail....lol
Old 09-12-2011, 11:32 AM   #4
OK after racking my brains for the past few months I have tested everything and have new CDI, Coil+wire, plug and pick ups are ohming good. Key switch seems to test fine and start stop witch as well. The reverse light is staying on now, would that be an issue? Even in High and Low the Reverse light stays on. I tried bypassing the Nuetral switch as well......NO SPARK....
yamaha moto 4 no spark
yamaha moto 4 350 no spark
yamaha moto 4 200 no spark
no spark on yamaha moto 4
1989 ymf 200 no spark
yamaha moto 4 250 1989 no spark
yamaha moto 4 250 no spark
week spark on my 95yamaha 350 moto 4
where is the fuse box for a moto 350 four wheeler
1993 yamaha moto 4 350 no spark
88 moto 4 350 cdi
yamaha moto 4 350 no power
88 moto 4 350 calipup72 Other Models/Brands 6 09-26-2016 09:19 AM
93 kodiak pull=spark, elect. start= no spark Help kbs@color-country.net Other Models/Brands 0 11-30-2010 03:00 PM
89' moto 4 yfm200 with no spark. ironfist104 Other Models/Brands 0 06-20-2010 07:16 PM
