timberwolf/bear tracker rear axle interchange - Yamaha ATV Forum
This is a discussion on timberwolf/bear tracker rear axle interchange within the Other Models/Brands forums, part of the Performance /Technical category; I recently bought a 94 Timberwolf 2wd with a stripped rear axle spline. I can get a great deal on a axle that is listed ...
Old 12-30-2010, 09:14 PM   #1
View jcronk69's Photo Gallery(0)
Default timberwolf/bear tracker rear axle interchange
I can get a great deal on a axle that is listed to fit a bear Tracker. From what I can find these ATV's were very similar, wondering if anyone knows if I could put the Bear Tracker rear axle in my Timberwolf?
jcronk69 is offline   Reply With Quote
Old 01-10-2011, 08:24 PM   #2
View team_realtree's Photo Gallery(0)
I've tried to do this same thing and when I looked into it the part numbers didn't match. I can't say it won't work for sure but you can get a timberwolf axle for cheap on ebay.
team_realtree is offline   Reply With Quote
Old 05-28-2012, 06:15 PM   #3
View powerblaster's Photo Gallery(0)
I have a timberwolf 1997 and tried to swap out the whole swing arm and also tried to just swap the final drives, they do not match the bear tracker has a bigger gear ratio also the swing arms are diff. hope that helps.
powerblaster is offline   Reply With Quote
find me a cheap used rear differential for a yamaha timberwolf
axle spline count for yamaha 250 timberwolf
timberwolf rear differential swap
rear end for a yamaha bear tracker 250
usedrearaxletimberwolf
yamaha bear tracker rear differential
yamaha 250 timberwolf rear differential
yamaha big bear and timberwolf interchangeable rear end
will bear tracker rear swing arm assembly replace a timberwolf rear swing arm
is a bear tracker 250 and a timberwolf 250 interchangeable
1998 yamaha timberwolf 250 has rear axle issue
rear axle stuck in 1987 big bear gonefishin0403 Other Models/Brands 2 04-12-2013 11:55 AM
Bear Tracker electronics? bomber315 Other Models/Brands 0 08-05-2009 07:32 PM
Bear Tracker pull start Jimmah Other Models/Brands 4 03-18-2004 10:40 AM
02 Bear Tracker YAMA-MAN5 Other Models/Brands 8 09-20-2002 10:22 AM
Bear Tracker YAMA-MAN5 Other Models/Brands 1 05-27-2002 11:53 PM
