'89 Moto 4 250 no mid or high-end power... - Yamaha ATV Forum
This is a discussion on '89 Moto 4 250 no mid or high-end power... within the Other Models/Brands forums, part of the Performance /Technical category; Ok, so I finally got he moto 4 running about two weeks ago.. turned out it needed a valve job BAD... so, I got the ...
Old 06-01-2010, 07:52 AM   #1
View cableguy256's Photo Gallery(0)
blah '89 Moto 4 250 no mid or high-end power...
Ok, so I finally got he moto 4 running about two weeks ago.. turned out it needed a valve job BAD... so, I got the thing running, new spark plug, carb is spotless... I had to hijack a piece of exhuast off of an old dirt bike (4-stroke) to use on my quad since it didn't have the header pipe when I bought it... The pipe I put on doesn't seal real good, now for my question... the bike seems to run ok on flat ground, but as soon as I start up any grade, it just loses all power. most times i have to put it in low-2 to get up slight hills... also it will not rev up past half throttle even if sitting in neutral. Could this be caused by the exhaust or do I have some other issue going on here??
Oh yeah, also I have tested compression and it's running at 153psi and the timing is dead on... Any help or suggestions will be greatly appreciated.
cableguy256 is offline   Reply With Quote
Old 06-07-2010, 04:35 PM   #2
Sounds like a needle and seat issue. That would be the first suspect when changes in grade affect performance. Turn the gas off and pull the fuel line, pull the bowl off and see how full it is. It should be 2/3 or less.. If it is too full of fuel the carb bowl does not vent properly and can suck up extra fuel. If the bowl is nearly empty you will have to adjust the float to keep more gas in the bowl.. If you have never changed the needle and seat it is an inexpensive preventative maintenance issue if you have the carb off anyway.
Old 06-07-2010, 06:49 PM   #3
I'd start by sealing that exhaust!!!! backpreassure is critical on a 4-stroke. Then work on the carb tuning.
yamaha moto 4 valve adjustment
moto 4 250 valve clearance
yamaha moto 4 250 valve clearance
yamaha moto 4 250
yamaha moto4 250 valve settings
valve clearance yamaha moto 4 250
350 yamaha moto4 valve specs
valve settings yamaha 250 moto 4
ajusting valves on moto 4 250
1990 yamaha yfb250 moto 4 valve clearance
yamaha moto 4 250 carburetor screws
1991 moto 4 valve adjustment
warrior gets no mid to high range power drummer247 Yamaha YFM350 Raptor/Warrior ('87-Present) 15 12-03-2009 05:30 PM
Exhaust: Does High Power Always Cause High Decibels? Oregon Raptor 700 Yamaha YFM700R Raptor (2006-Present) 20 01-16-2007 07:52 PM
not good. super high compression with vitos power pistons. roosthrower Yamaha YFZ350 Banshee (1987-Present) 18 01-26-2004 06:52 PM
High cmpression heads and power? banshze Yamaha YFZ350 Banshee (1987-Present) 8 01-12-2003 06:21 PM
