03-05-2010, 07:08 PM
1986 Moto 4 225 won't stay running
My '86 Moto 4 set up all winter. I had a hard time geting it started. I drained all old gas from tank and put in fresh. Took carb apart and cleaned. Still starts hard and won't stay running. It acts like it's starving for fuel. It will run for 200 yards and then just die. I took carb off again and cleaned again, blew out with air, still same thing. It seems to run better with choke on 1/2, but will still die out after in a minute or so. It pops and runs ragged with the choke out, maybe 2k rpm. Any advice will be appreciated.
03-06-2010, 06:02 AM
remove the petcock and clean it out. did you actually remove the carb and clean out the jets?
03-06-2010, 10:13 AM
Yes, I cleaned the jets and every other hole. Are there and carb adjustments other than idle speed? Now that you mention it, the petcock was frozen up and I broke the handle off, but when I took the fuel hose off the carb the gas seemed to run out pretty good. Anyway, I have a new petcock to put on. Thanks.
03-07-2010, 06:59 PM
OK, I have replaced the petcock. I checked the plug and it's dry as a bone. I disconnected the gas line at the carb and the gas flows nicely out of the tank, but still no start. After it sets for a day, it will start right up and run for about 10 seconds then die and won't start again. I think I have a definite fuel flow problem. The carb floats are not "water logged".
06-05-2010, 11:43 AM
Moto4
I had the same issue with a Moto4 200 I just bought. I installed a complete carb rebuild kit and it runs great now. Good luck
06-07-2010, 03:31 PM
Replace the needle and seat and pay particular attention to getting the pilot jet and passages clear.
06' Wolverine
1986 yamaha moto 4 225 specs, 1986 yamaha moto 4 225 carburetor rebuild kit, 86 moto 225 4 wont idel, 1986 yamaha 225 moto 4 wont start, carb adjustment on yamaha moto 4 225, 1986 yamaha moto 4 225 wont idle, yamaha 4 moto 225 wont idle, 1986 yamaha moto 4 pet cock, yamaha moto 4 wont idle, 86 moto 225 4 wont idle, 1986 yamaha moto 4 225 reviews, 1986 yamaha moto 4 225 carb rebuild kit
