Best way to get rear axle out of a wolverine? - Yamaha ATV Forum
This is a discussion on Best way to get rear axle out of a wolverine? within the Other Models/Brands forums, part of the Performance /Technical category; I am trying to get the rear axle out of my wolverine to replace the bearings, what is the easiest way to get the axle ...
Old 08-17-2002, 08:01 PM   #1
View Deer_Slayar's Photo Gallery(0)
Default Best way to get rear axle out of a wolverine?
I am trying to get the rear axle out of my wolverine to replace the bearings, what is the easiest way to get the axle out?
1999 Wolverine 350 4x4
Deer_Slayar is offline   Reply With Quote
Old 08-18-2002, 08:12 PM   #2
View LotusPosition's Photo Gallery(0)
Remove both rear wheels. Take off the rh hub, brake caliper, rotor and caliper bracket. It's not necessary to disconnect the brake hose, just unbolt it and carefully move it out of the way. The axle comes out from right to left, it should come out with light hammer taps. DO NOT hit the end of the axle with a hammer!!! Either use a wood block or a rubber faced hammer. There is a small o ring on the rh side of the axle, don't lose it, it does not come with most axle bearing kits. While it is out, change BOTH axle bearings. If you are unsure of what you are doing, get someone knowledgable to help you.
06 700R
LotusPosition is offline   Reply With Quote
Old 08-20-2002, 07:23 PM   #3
Thanks. I finally got it out. By the way, how much did the tires slow you down? Mines stock right now, with a cobra utility exhaust on the way and i was wondering how good it would pull slightly bigger tires. Also what was the best mod you have done on your wolverine so far? Thanks again.
Old 08-20-2002, 10:06 PM   #4
My bike had 26's on it when I bought it, so the 24's made it quicker! I feel that they are a nice compromise, a little more GC, without affecting quickness.
Best mod? Hard to say. A pipe will help, but usually rejetting is required , too. Remember, a stock bike will outrun a bike with a pipe that is not jetted right.
Skids and cv protectors are must if you ride rocks or other tough stuff.
06 700R
removing wolverine 350 axle
how to remove rear axle of a 1999 350 4wd yamaha
yamaha wolverine rear axle removal
yamaha wolverine rear end
free how take apart 97 wolverine 350 rear differential
easy way to take apart a 03 wolverine 4wheeler
2006 yamaha wolverine 450 rear differential
how to change rear oil seal on a 1995 wolverine
02 yamaha wolverine 350 axles
2003 yamaha wolverine 350 4x4 rear end
how take apart 97 wovine 350 rear differenital
yamaha wolverine rear hub removal
Rear axle Blackrappy Yamaha YFM660R Raptor (2001-2005) 1 05-04-2008 02:36 PM
Wolverine front and rear bearings. cumberland Other Models/Brands 1 12-05-2006 09:37 PM
What Gear Oil for Wolverine Differential and Rear Drive edge Other Models/Brands 3 12-18-2004 04:25 PM
wolverine rear brake on a warrior? nicko Yamaha YFM350 Raptor/Warrior ('87-Present) 0 07-21-2003 07:52 PM
rear axle lil_khris_warriorracer Yamaha YFM660R Raptor (2001-2005) 0 03-09-2002 02:28 AM
