Grizzly 600 has no spark!! - Yamaha ATV Forum
This is a discussion on Grizzly 600 has no spark!! within the Other Models/Brands forums, part of the Performance /Technical category; Hello all; My 2000 Grizzly 600 wonít stay running. The problem appeared while running down a level dirt road at 50 Km/hr and then the ...
Old 03-12-2002, 10:55 AM   #1
View Caper's Photo Gallery(0)
Hello all;
My 2000 Grizzly 600 wonít stay running. The problem appeared while running down a level dirt road at 50 Km/hr and then the ATV just quit running. I coasted to the roadside, stopped and restarted the ATV right away. I then drove another 20 K when it once again quit running while going down a hill, I stopped once again to restart the ATV but she wonít stay running. The engine will start after some effort and then idle for no more than 10 seconds and the moment you touch the throttle it stalls. I got the ATV home and I checked for spark (GOOD SPARK) replaced the spark plug (OLD PLUG GOOD TAN COLOR), check the fuel line, remove the needle and jet checked the float and reassembled. At this time the ATV started right up and idled and rev under throttle for about 5 minutes. I let the ATV idle some more when it just quit, I restarted and it once again idled as normal for about 3 minutes before stalling. I have not been able to restart it since. It almost seems to starve for fuel or could this be an electrical problem? Like I said the ATV runs and idles normally and then just quits like when you use the kill switch. All comments or suggestions would be appreciated.
Thanks, Jeff Sutherland
2000 Yamaha Grizzly 600
2300 Km since new.
Hello all;
Hereís an update on my Grizzly problem. I donít have spark any more!! I have checked for the ignition pulse at the spark plug coil while cranking the engine and have even held the spark plug in my hand and guess what, no shock. I have verified the connection from the coil (orange wire) to the C.D.I. UNIT ASSY. Does anyone have an electrical schematic that you could e-mail me or know of anyway to test the C.D.I. UNIT? I also checked every connection on the ATV and they all look good, inside and out checked all fuses and reseated them. All comments are welcome.
Thanks, Jeff Sutherland.
_________________
Caper is offline   Reply With Quote
Old 03-12-2002, 03:53 PM   #2
screamin96's Avatar
Hmmmmm...well as far as I know, there is no way to check the CDI unit. So the orange wire going to the coil is getting spark? Or no?
Old 03-12-2002, 04:38 PM   #3
The orange wire from the CDI UNIT to the spark plug coil ohms out perfectly. When I put my 12volt lamp tester on the coil and crank the engine I don't get and voltage going into the coil. Could this also be a STATOR problem??
Thanks for your response, Jeff S.
Old 03-13-2002, 03:40 AM   #4
screamin96's Avatar
Could be the stator. Check the resistance with an ohm meter. But for some reason it sounds like some kind of safety switch somewhere.
Old 12-01-2010, 07:01 AM   #5
View john j's Photo Gallery(0)
I also have a 600 grizzly and I don't have any spark either I tried the cdi and the stater also a new ignition coil I don't know where all the safetyswitches are does any one know everything that has to be made for this atv to run .
john j is offline   Reply With Quote
Old 12-11-2010, 07:11 PM   #6
View michfanlg's Photo Gallery(0)
I was running my 450 Kodiak today and it just stopped running. I'm not getting any spark at the spark plug. Does anyone have ideas as to what I should or could do to fix the problem?
michfanlg is offline   Reply With Quote
Old 12-17-2010, 12:23 AM   #7
View shivam's Photo Gallery(0)
If you had a bad stator and changed it to get spark the first time around, why do you not suspect the replacement stator being faulty?
Did you replace the other ignition components with new or used?
shivam is offline   Reply With Quote
1998 yamaha grizzly 600 no spark
no fire 2006 grizzly
98 yamaha grizzly 600 has no spark
yamaha grizzly 600 weak spark
yamaha grizzly 600 plugdontfire
2000 grizzly 600 no spark
98 grizzly 600. no fire
has anybody tried cdi box off yamaha grizzly 660 on grizzly 600
4sh-00 7yp
grizzly 600 ignition problem
yamaha grizzly spark issues
660 Grizzly, HELP! newraptor660 Other Models/Brands 1 02-04-2008 11:42 PM
New Grizzly! Pokey Other Models/Brands 2 03-22-2005 09:36 PM
660 grizzly wells_rider_87 Other Models/Brands 5 05-17-2004 11:12 PM
Spark plug will not spark custom_warrior Yamaha YFM350 Raptor/Warrior ('87-Present) 3 09-22-2003 04:31 PM
