wolverine carb - Yamaha ATV Forum
wolverine carb
This is a discussion on wolverine carb within the Other Models/Brands forums, part of the Performance /Technical category; I added an HMF exhaust on my wolverine and rejetted it and I am needing to richen my air/fuel mixture screw. The problem is it ...
Old 02-10-2004, 08:23 AM   #1
View hotrodbanshee's Photo Gallery(0)
Default wolverine carb
I added an HMF exhaust on my wolverine and rejetted it and I am needing to richen my air/fuel mixture screw. The problem is it is froze up and I can't get it to turn. The soft brass head stripped on me when trying to turn it with a flathead screwdriver. I don't know how to get it out without drilling it out. I am not getting enough fuel right off idle. My dealership said I am going to have to get a new carb, about $300+ for one thru the stealership. Anyone know where I can get a good used carb for my wolverine? Are there any other carbs that work other than the one that comes on it from the factory? I have a 1999 wolverine Mikuni 34mm carb.
03 shee limited, t5's, noss head 21cc domes, pro flow with K/N, ac nerfs, durablue axle, durablue wheel spacers up front, flame engine side covers, flame radiator cover, alba flame front bumper
99 wolverine, 424 select, durablue axle, HMF exhaust
hotrodbanshee is offline   Reply With Quote
Old 02-10-2004, 08:41 AM   #2
View trailboss's Photo Gallery(0)
www.ebay.com
00'Blaster with Maier, FMF, boyseen, T-9s, klaws, K&N, etc.
98 Ram with jet, flowmaster, rancho, interco, rhino, and so much more
trailboss is offline   Reply With Quote
Old 02-10-2004, 09:03 AM   #3
Already checked ebay, no luck.
Old 02-10-2004, 04:00 PM   #4
View blaster105's Photo Gallery(0)
well if the screw head is out some get a thin cutting tool and cut a slit in the screw head in a good spot.also u can head it up but it migh melt the oring but u can always clean it out after and if u get it out after heating it up
blaster105 is offline   Reply With Quote
Old 02-10-2004, 04:05 PM   #5
The screw is about 1/8 inch down inside the carb, no way of making a slit on the head of the screw.
Old 02-10-2004, 06:44 PM   #6
would there be room there for a screw extracor of some sort? Without damaging the carb itself. try some bolt spray to try to loosen it up and if all else fails try drilling it carefully
Old 02-10-2004, 07:06 PM   #7
View mxthunder's Photo Gallery(0)
:) Sounds good. Are you sure that a dremel won't do the trick? Don't buy a new carb yet. There is still hope. Let the carb soak in carb cleaner over night. That may eat all the junk off thats locking up the screw. It may damage some o-rings and seals, but you will just have to replace those.
04 YFZ450 - WR crank, oil mod, CP 13:1 piston, Full Yosh TRS Ti pipe, hotcams intake, cam mod, YZ clutch mod, GYTR basket, FCI, 1" lowering peg nerfs, LSR axle, Pro tapers and Housier +1" stem, PRM desert grab bar, AC bumper, XCR tires and more 175M NCVQ #5 50p | 2010 YFZ450X - HMF Tuner, PRM bolt-ons, Aluminum airbox + K&N Filter
mxthunder is offline   Reply With Quote
Old 02-11-2004, 08:12 AM   #8
I used a dremel tool and shaved the housing down level with the top of the screw head. I have it soaking in carb claener right now. I am going to cut a slit in the head of the screw and see if it will break loose. I sure hope this works.
Old 02-12-2004, 08:03 AM   #9
Still no luck. The brass is to soft, keeps stripping.
Old 02-22-2004, 09:58 AM   #10
View shee2quick4u's Photo Gallery(0)
Default Re: wolverine carb
Drill it out or buy a screw extractor at Sears,
01 Black Banshee, Tribal Flame Graphics
FMF SST Pipes
Pro-Flow w/UNI
Cool Head w/22cc Domes
For Sale
2 Yamaha Zuma's
For Sale
02 Blue Wolverine
Alba pipe kit
K&N
Torque Stuffer
Hi-Lifter Un-Locker
Dial-a-Jet
For Sale
02 Black RAPTOR
FMF Titanium 4
Flame Graphics
Pro flow w/K&N
Dial-a-Jet
for sale
shee2quick4u is offline   Reply With Quote
Old 02-25-2004, 04:07 PM   #11
I took a torch to it and it came out. All fixed up and runs great.
Old 02-25-2004, 06:02 PM   #12
i told you could heat it up in the begining. glad it worked for you.
1997 yamaha yfm350fx wolverine aftermarket carb
mukuni yamaha wolverine 350 carburatoroperation
what mikuni carb yamaha wolverine
mikuni 4kbm 22
03 yamaha wolverine 350 air screw stock turn set
98 yamaha 350 wolverine carb parts
1999 wolverine carb problem
woolverine mikuni carburetor
mikuni 4kbm yamaha wolverine carburetor
1999 yamaha wolverine carb kit
yamaha wolverine 350 carbirator air cutoff cover
air fuel mixture on yamaha wolverine
Raptor 660 ported head, edelbrock carb, Grizzly carb Swansonator Parts for Sale 2 12-10-2008 07:10 PM
wanted carb for wolverine lockall4 Wanted 2 07-13-2007 05:18 PM
Warrior carb on a wolverine 2000wolive Other Models/Brands 2 03-30-2004 11:39 PM
Carb warrior/wolverine hotrodbanshee Yamaha YFM350 Raptor/Warrior ('87-Present) 4 02-12-2004 03:16 PM
Wolverine and warrior carb 2000wolive Other Models/Brands 0 05-15-2003 02:06 PM
