Big bear 4 wheel drive - Yamaha ATV Forum
This is a discussion on Big bear 4 wheel drive within the Other Models/Brands forums, part of the Performance /Technical category; hey guys, I just got this Big Bear 400 4 wheel drive. Today I was pulling a heavy ice shanty. When starting out on the ...
Old 01-18-2004, 06:05 PM   #1
View Kanes28's Photo Gallery(0)
Default Big bear 4 wheel drive
hey guys,
I just got this Big Bear 400 4 wheel drive. Today I was pulling a heavy ice shanty. When starting out on the ice I noticed the right front tire wasnt spinning.
Is this normal? One guy that was with me thought it may be a limited slip rather than true 4 wheel.
any thoughts?
thanks... Kane
Kanes28 is offline   Reply With Quote
Old 01-18-2004, 09:14 PM   #2
View Punisher's Photo Gallery(0)
Yea the BB doesn't have a locker. Highlifter does sell locker kits for them though.
99 Blaster
-HDP carb rifle, The prop,
-Toomey B1
-Moto Tassinari Delta 2 Reeds
-Shredders in the rear
-2.5" Durablue rear wheel spacers
Punisher is offline   Reply With Quote
Old 01-23-2004, 06:09 PM   #3
View JumpinJer's Photo Gallery(0)
yes kanes, It has an unlimited slip differential(thats pretty much how it works like) So the tire without the traction will spin, The one that actually could pull you forward won't thanks to bad design.
03 Cannondale Moto-Walsh Custom Axis Front
02 Cannondale Cannibal
04 Bombardier Outlander 400 H.O 4x4
04 Kawasaki V-Force
JumpinJer is offline   Reply With Quote
Old 01-23-2004, 06:59 PM   #4
View ATC Crazy's Photo Gallery(0)
Next time you find yourself stuck (wheather in mud/snow/etc...), and only 1 of your front tires is spinning and the other is just sitting there....Apply the front brake a little at a time and it will "lock" the front end. At least it does on my Foreman. I would try that a few times before I wasted my money on a locker IMO
Former Ride:
2007 Yamaha Raptor 700R SE
ATC Crazy is offline   Reply With Quote
Old 01-23-2004, 09:09 PM   #5
Ya that just your forman. It has a more advanced differential than the bear. I don't think it will work on it
04 Kawasaki V-Force
Old 01-23-2004, 11:19 PM   #6
That's a little trick that works on all 4x4's without a locker.
The only advantage to having a 3 wheel drive set up is you are a lot less likely to snap an axle shaft.
99 Blaster
-Toomey B1
Old 01-24-2004, 12:09 AM   #7
I also said try it.
...And unless something is wrong with it, the axleshaft will not break with the power output of the Big Bear....
Former Ride:
Old 01-24-2004, 12:24 AM   #8
It's not just about engine power output. Tire size and weight play a big role. Also the year of the BB. Yamaha used a different axle shaft for all their '03 4x4 Utilities that are more prone to break.
99 Blaster
-Toomey B1
Old 01-24-2004, 12:33 AM   #9
Ya atc crazy, Now that i think about it i can see how it would work.
04 Kawasaki V-Force
2003 yamaha big bear 400 4x4 4 wheel drive trouble
why would i lose rear wheel drive on my yamaha big bear
can you take a 4wd locker off of a 400 yamaha big bear and put it on a 350 yamaha big bear?
2001 big bear 400 4x4 engage
yamaha big bear 350 4x4 all wheel drive
is a 01 big bear 400 always 4 wheel drive
how does the four wheel drive work on a 95 yamaha big bear work
fromt wheel drive not working on yamaha 400 bruin
big bear front diff lock trick
yamaha big bear four wheel drive 4x4
2007 yamaha big bear 400 won't go into 4wd
does anyone make a kit for a 2000 yamaha big bear 4x4 to make it shift in and out of 4 wheel drive
Bruin 250 2 wheel-drive lift kit info bullardmuddin'50 Other Models/Brands 0 02-17-2007 06:06 PM
2 wheel drive WR450 -YRT- Other Models/Brands 25 08-12-2004 06:15 PM
I don't need no stinkin' 4 wheel drive! RaptorJet Yamaha YFM660R Raptor (2001-2005) 19 10-17-2003 10:44 PM
problem with 4 wheel drive? Kanes28 Other Models/Brands 1 09-03-2003 08:45 PM
greasing wheel bearings on big bear 03bigbear4x400 Other Models/Brands 2 10-16-2002 05:06 PM
