11-05-2003, 04:14 PM
how much does a honda 250r weigh ?????????
i just wanna know how much a honda 250r weighs.and how there power is.im a 210 pund guy and im trying to decide if a 250 will be ok for racing or if a banshee would be better bcz im bigger?thanks and id like to know the weight over a banshee
just shut up and race me
11-05-2003, 04:54 PM
They 250R would have plenty of power for you...trust me, Im 260lbs.
Former Ride:
2007 Yamaha Raptor 700R SE
11-06-2003, 07:01 AM
yeah you will love the 250R's power and the size shouldnt be a problem
11-07-2003, 06:57 AM
what kind of racing? the 250r would be a lot bette if it were like mx or somthing like that,the 250r would be perfectly fine, and if not you can do a lot of work to those puppies
97 mx blaster 30mm mikuni carb,
WSM aluminum piston,bored.50 over,
AC racing nerfs- grab bar,
FMF exhaust,
boyesen reeds/ spacer,
Trenga intake,
front end extended 4"
PD tether,
K+N Filter,lid-less
BAnshee front shocks
front 19" holeshtos
cut front and rear fenders,
alloy bars,
18" turf tamers on doug redlabels
11-07-2003, 08:00 AM
They can weigh around 300pds wet ,some alittle more some less. You will not make a mistake if you get. They are over 15yrs old and have one of the best frame geomtry.
11-07-2003, 03:44 PM
the blaster weighs 320 so i would guess like 290 or 300?
00' Banshee
96' Red SVT Cobra
"COBRA FROM HELL"
11-10-2003, 06:09 PM
The official wieght for a 250r is listed as 328lbs dry (no gas, no oil), the banshee wieghs in at 386lbs dry.
If you're planning on racing, the 250r is definitly the way to go. Yes, the banshee has more power, but races are not won in the straights, they are won in the corners and technical sections. Keep your speed through the corners instead of playing catch-up in the straights.
I'm 220lbs, and my 250r doesn't feel small to me at all. If you plan on racing on a limited budget, upgrade your suspension before you upgrade your motor.
honda 250r weight, how much does a honda 250 weight, how much does a yamaha 250 weight, how much does a honda trx 250 weight, how much does a honda 250r weigh, honda 250 atv weight, 2007 honda 250r weight, how much does a honda trx 250 weigh, how much does a 250 quad weigh, weight of honda 250 atv, honda trx250r weight, how much does a 250 motorcycle engine weigh
